Is joule thief circuit gets overunity?
Started by Neo-X, September 05, 2012, 12:17:13 PM
ltseung888
ltseung888
Just to re-confirm that Board 80 actually have the input current crossing 0 axis behavior.
Raw data is presented.  Note that in the 4th file, the scales were changed to display curve on screen.
The Input DC Power Voltage was adjusted until the LED was just turned ON.  The 4 files showed the waveforms displayed at 4 Input voltage values.
Lawrence, when the probe compensation issue first came up, one of your probes showed a large _voltage_ discrepancy. I've asked you several times about this discrepancy. What caused it, how was it cured, what evidence is there that the discrepancy is cured?
Why not forget about the LED light output and just use the input voltage that you used for that first screenshot above.
The indicated current is "always" positive, which means it "always" is flowing INTO the battery or capacitor supply and should be charging it up.  The COP value for this voltage input should be very large indeed.
Right?
ltseung888
