Probality of God
Started by Newton II, September 14, 2012, 01:33:36 AM
eatenbyagrue
Quote from: Bruce_TPU on November 18, 2012, 04:57:29 PM
I do not believe the Universe is 6,000 years old.  Only those who have not rightly divided the Word of God (Scriptures) say that.  Below is a great visual, by Clarance Larkin (R.I.P.)  Author of the Dakes annotated Bible and many books.  His drawings and understanding of the dispensations are some of the best there have ever been, even though they are very old now.
This is just one.  If you are interested in reading his write up that goes with this drawing, just let me know and I will be happy to post it.
Walking with Jesus,
Bruce
This is heresy and blasphemy.  The bible provides a complete and accurate genealogy, when compiled and counted adds up to about 4000 years.  Add 2000 years since the Bible, and you get an earth about 6000 years old.  Any attempt to argue this is an affront to God himself.  God did not bother to write the Holy Word and spell out genealogy in great detail for humans to argue with it.  You will surely burn in hell for this blasphemy, Bruce.
Bruce_TPU
I said "I do not believe the UNIVERSE is 6,000 years old".  I said nothing of modern mans existence.  As always, your failure to both read and understand is mind boggeling.
How can I debate against the twisted thinking.  I can only point to the truth in hopes that many readers actually have much more discernment and snap then I see demonstrated from this rabble.
For those who worship intellectual persuit, the lack of basic understanding of even primal things, like "reading comprehension" is truly apalling.  So what do these intellectual giants then do?  They go back to their baser nature of name calling.  Like the apes they claim to descend from, beating on their chests.  When in truth, they are goats, being blindly led down the path of destruction.
Repent now, call upon the Lord Jesus Christ, while there is still time.  For THAT day is fast approaching.....
Maranatha,
Bruce
hoptoad
Quote from: Bruce_TPU on November 18, 2012, 07:37:30 PM
snap...
snip.....
Base is as base does
eatenbyagrue
Maranatha,
Bruce
You repent, blasphemer!  This earth was created in a few days just before the creation of Man.  I am honoring our God by spreading the good word that the earth is only 6000 years old.  You, however, will surely burn in hell for your blasphemies.  Blasphemer!
gravityblock
Quote from: Gwandau on November 18, 2012, 03:20:17 PM
Tommy,
you are shooting far above the rigid heads of these fundamentalistic "true to the letter"-fanatics who all belive the universe is 5500 years old and who all are expecting a Doomsday treat to their favour any day now.
They have made their own prison of ignorance and calls it the temple of truth. They are their own wardens and gards, and the possibility to escape into freedom is extremely small, if possible at all.
Every idea or thought process that may threaten their illusion is either ignored or labeled as blasphemic. It is a water tight system, created many hundred years ago by a bunch of pre gnostic geniuses most likely on a horrendously bad trip.
Christianity thus has since long left what was a genuin understanding of the enlightened Jesus. Deformed into its own anti christ, hiding behind the facade of righteousness, propelling a twisted version of the pure and simple wisdom of Jesus into their dogmatic mental torture cells of guilt and fear, Christianity now are doing more harm than good, adding to the overall duality and splitting mechanisms effected upon humanity today.
Since these people observe the world through their multiple defracting layers of dogmatic filters, everything they see is but a projection forced upon reality to keep the Christian dogmatic fundament intact, so don't expect that anything you say might reach them in the originally intended form.
It's interesting to study for a while, but if the reason for your presence is compassion, the understanding of the predicament of these people unfortunately will make you somewhat sad.
Gwandau
Where did I say the universe was 5500 years old?  I actually think the earth is much older than what religion itself teaches.  It says in scripture a day is like a 1000 years.  In fact, I have already posted that in a prior post.  Also, at the end of the 5500 years I speak of, things will be restored and made new again.  God's children will live in piece for a 1,000 and then the adversary tempts the children of God again and the process more than likely continues another cycle.  The religions of today have been corrupted by the adversary just like science, government, etc.  However, God's Word still remains True if one takes the time to truly understand it.
This is the problem with you, I say one thing, and you automatically and wrongly assume another thing.  You don't even try to understand what I'm saying.  You have your own preconceived ideas and then try to wrap that around what I say.  Your not true with yourself or anyone else.  You walk after your own lusts and desires at any cost, and you reject God because you don't want to be accountable to anyone.  You can reject Him if you like, but you will be held accountable. It amazes me how you hate us so much for having faith in a God, who you reject or don't believe in.
Gravock
