Free Electric Multi-use motor - Home gen-Car motor-Boat Motor-lawn mower
Started by inventacom, September 15, 2012, 11:13:45 AM
e2matrix
Quote from: gadgetmall on September 20, 2012, 06:59:01 PM
Ok . I used to use a program that does exactly that . you take a file and encode it with a tiny program . the receiver would run a command line program to generate his unique checksum key that is sent to the sender ,the sender adds this checksum to the tiny program which is added to the file   /.. . once that person received the  file his key would open that file . the file would then unzip and unlock for him .the program that is the file  did not allow copy and paste or any function keys to work  and  if he tried to share the file and key to someone else it would not work . i think it was called stanware . used to use it a lot passing files ,disk etc,, anyways thats how we did it to protect our property , A single file can be shared with only the people you want it to go to without a worry that it will be passed . that is how we track a file.
I think i will stick with  pm as a backup to you  . I will upload it to a secure site and Pm the link and passcode but i like the idea of the auto-responder too. we need to get together on  one passcode in Pm .
gadget
Ps . I invited/nominated  Bill but he has to get Mod status over here from Stephan to moderate . He only moderates joule thief . i don't think it will be a problem and we need him if he accepts .
Of coarse if stephan was here he could moderate it but seems to be MIA :) I like your suggestion too gyula .
the problem if it is a problem is trolling trolleys trolls can easily infiltrate with a newbie account .
That sounds a lot like PGP with it's keyrings.   Would that work to protect pictures, videos and so on from being spread after a person had them and opened them?  If a person has a picture open would it keep them from doing a print screen to capture it?  In most cases anything that can be displayed in a video or picture can be captured if not by a program than by a decent hacker.  I don't think we have to worry about a level of security much beyond a password protected Zip file because if someone wants this info bad enough they would just sign up at overunity make a couple dozen posts and join in the discussion here.   If what you mention is like PGP or PGP based I think it gets a bit more complex than some might want to deal with and I'll bet some people have never seen DOS or a command line.  I still do things in DOS that can't be done any other way but then I've got every version of DOS since v1.0   ;)
    Very glad to see you here gyula.   Inventacom may not know your level of expertise yet so I'll say anyone who's been around here a while knows you are one of the true component and circuit geniuses.
    If anyone else has thoughts on methods for the file sharing please let us know.  Inventacom will of course have the final say.
e2matrix
I'm just guessing but he did mention he had none of the info in his computer and had to get some things scanned in at someone else's place so I'll assume he will be here later or tomorrow with more info.   So for now he may not be able to respond to email readily.
    I'm going to post a couple questions for Inventacom which can hopefully be answered with some clarity to help keep everyone here interested and to help answer some things that I'm sure are buzzing in a lot of minds right now.
1.  Once the device is started can it self run keeping both the battery charged (if it is still in the system) and provide external power to a home, car or devices without any other external source of input (such as fuel, external electrical power etc.)?  This of course does not include Zero point energy or other unseen energy that may be entering the system somehow.
2.  If it is COP > 1 or overunity or free energy (and yes we all know those definitions are open to interpretation and much confusion but for basic discussion I'm sure everyone knows what the intention is with this question) is there a theory or known way as to how this is getting extra power?   If not we will work on that but if it is known I believe it will help reinforce interest in replications.
3.  My own question because I think there is a possibility this may be similar to a couple other devices I know of -- what is the approximate weight and diameter of the pulley that goes on the fan motor?  And is there some slack in the belt that goes to the the generator or is it fairly tight?
4.  If I'm correct about the generator I see in the pictures I think those need to turn at around 3600 RPM to produce 120 volt AC.  Is that close to the speed this runs?
gadgetmall
E2matrix . Well it is like pgp except this program generates files to an EXE . when executed you enter your key . the program opens up whatever pictures videos text inside this tiny program . You are the able to view the files but the functions are disabled like print screen or copy and paste and will not allow you to make a copy that way . if the file is sent out of group with a copied key it will not open . Yes it is like a Shell type PGP . it is very powerful in that you can make Disk copies and send them to some one and they have a password . but also they cannot copy the disk . it was pretty neat but a hassle here i thinks . they have a new method really complicated called Multicast Encryption also .Like your satellite dish   except Internet based with unique keys that can be changed on the fly by the sender .  I know all the guys here really want to see it like normal but this is not normal .  this it is thought out pretty well to keep it out of the www but into a team .
Anyways we just need something to pass so we are waiting also guys . hang in there..
Edit :posted same time e2matrix and thank you for those Good Questions we all need to know .
I am Bushed and need a break from this screen and can't think properly and take it from here tonight if you can .
If any late breaking News arrives i will alert the team . I am up at 5am est so i think we might have an answer soon !
so with that lets ponder on the past inventions akin to this one  http://www.youtube.com/watch?v=qhwQt1tJYa8
http://www.youtube.com/watch?v=Fv53K9MnDuM&;feature=related
http://www.youtube.com/watch?NR=1&;feature=endscreen&;v=InZ9XtiKpXo
http://www.youtube.com/watch?v=hl57y-c_bWc&;feature=related
http://www.youtube.com/watch?v=h41oenbUGsE&;feature=related
http://www.youtube.com/watch?v=XG9chgbbweQ&NR=1&feature=endscreen&list=ULnhYAlh5Meuw
and this thing http://www.youtube.com/watch?v=Wk4m1MLZudE&;feature=related
Magluvin
Quote from: gadgetmall on September 20, 2012, 08:35:33 PM
E2matrix . Well it is like pgp except this program generates files to an EXE . when excicuted you enter your key . the program opens up whatever pictures videos text inside this tiny program . You are the able to view the files but the functions are disabled like print screen or copy and paste and will not allow you to make a copy that way . if the file is sent out of group with a copied key it will not open .
What about 'screen capture?  ;]
Well it seems like things are moving along here. ;]
Looks like we are in for the "long haul".  I hope its not too long. Just read an article that states that an asteroid will hit Antarctica this fall. They didnt use the word 'might', or 'possibly'. We could sure use 'power packs' if that happens, and head north.  Man, I hope not. Where they do state possibilities is water levels up 70 meters due to Antarctic melt. Where I am, I would have to be 200 to 300 miles north in order to see or be 'on' land if that were to happen. :o The original from http://www.phas.ubc.ca/article was taken down pretty quickly. 2 days.
Good luck guys. Ill be following. ;]
MaGs
e2matrix
Sounds good gadget.  I think I have or had a proggy like that too at one point.  I collect lot of encryption stuff and if you happen to find it if it's share/freeware I'd be interested in a copy.  Get some rest and take care - I know you had some battles a while back.  No need to overdue yourself here.  I'm usually up late so if anything breaks from Inventacom I'll pass it along.
    At this point anyone interested in getting any new files or info Inventacom wants kept within the team please wait until something is announced that is available then send me or gadget a PM.  I haven't heard from Inventacom yet so he may have other ideas but most likely we will wait for anything to be shared, interested members will send one of us a PM and I'll respond with the email address to contact where you'll get an auto-reply with links and password.   That's how I plan to do this now unless directed otherwise.
