0 Members and 651 Guests are viewing this topic.
NickZ
    Itsu: You said, "sucking power from your water well (ground)."
Just had to laugh....  good one.
    Thanks for the tips...  Yes, it does seam like my Kacher wants to run at lower 500Khz to 1Mhz ranges, to be effective. We'll see.
    According to my SG there are a lot of different resonant points, for the Kacher to run at. Of course there's always one best resonant point to chose to run with, if you can do so.  It helps to have a spectrum analyzer, to see where all these best peaks are at, in the first place.
DA1
Quote from: Jeg on November 19, 2015, 06:24:54 AM
Guys thanks for the capacitor info.
DA1, I see that you used the same as Ruslan's 220 to 24V converter. Did you make any changes inside it? I mean did you change its internal diode bridge for a quicker one? Do you have anything to advice us?
Itsu, if you have any good circuit for nanosecond generator I am interested in. I started to think about Dally circuit again. Back to the very first page again to study it closer this time. I also got sick with katcher.  :)
Hi  Jeg   & all     I do not change equipment
สวัสดี  jeg   และทุกท่าน  ผม ไม่ได้เปลี่ยนอุปกรณ์
Jeg
Quote from: itsu on November 19, 2015, 01:27:38 PM
Presently my toroid is the 10x6x4 one, so former is 4mm.
Wire is 0.28mm teflon isolated
L1 = 4 turns,  L2 = 12 turns
Best result was with a KD226D diode at 120V at 4.2Khz repetition frequency: 1500V / 12nS.
With higher pulse repetition frequency (15KHz), be sure to have enough cooling on the MOSFET, Schottky diode and toroid.
Regards Itsu
Thanks Itsu.  :)  Where do you adjust the repetition rate in your circuit? Or does it get synchronized through the KHz pulsed power supply of 150V yoke output?
AG. Thanks for the proposals. But why only to use the 74hc132? What about the 74hc00?
itsu
Quote from: Jeg on November 20, 2015, 04:31:16 AM
Jeg,
Dally used the VCO pot (upper left in the Dally diagram) to manually set the  repetition rate.
I use the outputs (via switch S1) coming from either the PLL (green box in the ALLEGGA diagram) or lately from my small TL494 circuit before it goes to the MOSFET drivers to drive the push-pull circuit.
These are synced with the push-pull circuit.
Itsu
Jeg
Quote from: DA1 on November 20, 2015, 02:21:45 AM
Hi DA1 :)
Thanks for your answer and for your photos! I really like your job because it is the most simple construction I have seen until now. You don't even use your Katcher!!!
If there is no problem I'd like to ask you some things more about the high frequency pulses.
Do they need to be rectified before the antenna or just an AC high frequency signal will work ok? I see that Dally used one way pulses with nanosecond generator. But seems that Ruslan uses AC. What is your opinion on this? AC works ok? Or needs a rectification before antenna?
Really appreciate your help. ;)
