0 Members and 313 Guests are viewing this topic.
Tomtech29
Hi.
magpwr
"If only someone can point us on how we can obtain TL494 Russian via online store as used in Akula video would be high appreciated. :
-so I moved already the subject of this IS the frequency of 2MHz. Yes on this page, someone will link where you can buy "Russ:
(me too, there was the question what to replace it)! but we do not know why there is this (Tl) and not another chip?
https://www.youtube.com/watch?v=8ml5JTp__Xw
You are missing here a particular schema, and the whole story!.
T-1000
Quote from: GeoFusion on January 16, 2016, 03:09:35 AM
The vid
https://www.youtube.com/watch?v=qEHKGSLy938
Mediator makes it all possible,
The way I see Akula Circuits managing the effect must be a mediator  in connections within the circuit boards for it to work.
no other way.
That's a good one, keep it up!
The next step is run it from the battery and use 220PSU input in the loop from the output. Also the sparking between ground wire and ground is a good sign for moving forward towards self runner.
Good luck!
AlienGrey
Quote from: Atommix93rdAtom1 on January 16, 2016, 09:40:34 AM
Batteries and ground wires ?? Oh dear hahahahahah No YOU GOT THAT WRONG !!! Alien gray Its time you made some progress and built something !
The problem is you guys like to many others have no formula for the production of energy ? Or any I dear where its going to come from ? So how the hell are you going to run it independently if you don't know what is going to power it ? So you think its some kind of high frequency loop ?? No ! In fact you may find that at 60 hz you will run it much better and is legal tender at that current with not to many health and safety problems.
No mention what so ever of a negative field or electron pairs with out that what ever you build will just drop down but at least you can just plug it into a battery hahahahahahahahahahah Battery's ahahahahahahaha !
You got all that kit hahahahahahhahahahahahahahhahah we don't even use a meter ahahahahahahhahahahaahahahahhahahaha !!! Mind it does look good on the web site here oh very professional hahahahahahahahahahahahahahahaah ...
I have decided to run a bookie and take bets who is first to isolated a sustain at 10 seconds hahahahahahahahahah And MR green is at 100 to 1 on that one but his odds on to be the first to kill him self hahahahahahahahahahahahaha
How many circuits have you now designed that are completely different from the one the inventor produced ???? hahahahahahahahahahahahahahahahahahah
As the weapon systems go well don't go for a dark laser and leave that modulation out of the circuit you only need that in case your attacked by aliens ! hahahahahan !!!!! Do you know what you lot are getting into ???? NO !!!! You don't have a clue your all stuck with collage mentality physics but your going to have to learn some very advanced quantum mechanics !!!
Did you know in a coil of wire you can move all the electrons to one side of the coil and when you have finished playing with your toys if you have over powered the coil the electrons will compress to one side of the coil so when you switch it back on you get a huge plasma discharge and it will kill !
There is no such thing as free energy its got a price to pay !!!! ....... These are not kids toys and are far more dangerous than MR alien gray hahahahahahaha lol good luck hahahahahahahahahahahahaah
Yes well I'm  not as stupid as you like to think,  Partial pairs, your on about anti Mary again ;) ;)I might know a good bit but none the less, unless i know what I'm doing I don't dabble with the nasty stuff,  I have asked a few where the energy is cumming from on here and none of them know ! so situation normal on this one while i find out more information this stuff.
However I have chatted with a few on here who recon they know what's going on, but if you listen to John Badini, Henry moray and others they talk about separating + and - electrons from each other with high voltage static separation oscillation and mixing to add energy for more output, but if you watch others experiments they end up with loss, i wonder why that could be ?
Then their is Eric Dollard now he knows what he is talking about, he says electrons exist in metal and for a hole to travel takes time as it's a wave and waves wast time generating magnetism, hence you get losses, now Tesla used Scala it's not the same, it's like me kicking you up the arse and you traveling along till you hit something ;) ;) ;)  that's not a wave it's pressure!
Quote > Alien gray Its time you made some progress and built something !  Question Like what and unless it's guaranteed to work forget it !
Hoppy
Geo,
You mentioned in your video that one of the push-pull transistors was getting hot, whilst the other one was running cold. This is exactly the condition that I had when the 'effect' was evident. The HV is having the effect of shutting down one side of the PWM and you will be able to disconnect one transistor and just run on one side - Tesla's unipolar pulse generator supplying the Kacher? Get yourself some measuring kit, like a DC clamp meter or scope and you will then see what's going on. As you have realised, keep that diode on your PSU to prevent smoke due to HV on the power rail. The PSU is working very hard by supplying a heavy pulsed current whilst the Kacher is running.
NickZ
   Geo:
   Ok, looking good.
   What I see is that the green toroid is working as a transformer which is raising the voltage that's going to your kacher's driver circuit, to more than just what your normal 24v, 15A PS is putting out. Although at the expense of some of the current.
   Your frequency is running at in the audible ringing range, at around 10kHz.  With a couple more lower frequency resonant points.
   We still don't know if you are reaching OU, or can self run, yet.
      Best of luck,
                         NickZ
    PS. I'll make a short video soon of your device as it's running in your video now, so that you can see what frequency you're running at.
     Atom: PLEASE start your own thread, as you have nothing of interest to us here on this Akula/Ruslan/Dally thread.
    Or...... get with the program here, by studying what is being attempted.  And not further disrupting and spamming us to your unrelated topics.
    I said, PLEASE, and am asking you in a nice way.
    Last call...
