0 Members and 28 Guests are viewing this topic.
John.K1
QuoteSo I would have to agree Geo, we have a system that is mixing amperage and voltage from two different
sources giving us real output power.
I do not fully agree. Only mixing imputed energy can't lead to OU.  Freaky guy Atom93 asked you  "What is the food?"   and he is right. What is the extra input into your system?  Just mixing given portions of input energies will lead to less energy out due to law of conservation of energy.   So before you mixing you voltage and amperage, where is that moment the extra energy enters your system and why?  Ruslan was speaking about it, I was telling you, I gave you a video where other Russian guy was talking about it (also wondered why Ruslan didn't explained it to you in more detail), Akula was talking about it . Listen what those guys say ;) That's my advice. I just blew off a dust from my device and will start to work on it soon again. Let's see.  Ruslan was also speaking about the possibility to use spark gap in his video. What does sparks do?  Still the same question. Push-Pull only spins the gathered energy- it is not a source. Showing videos running couple hundreds watts from push-pull it is just a inverter- nothigk more-nothing less.
See you soon.
Tomtech29
Hi.
I saw this stuff, and I have the impression that, as it turned kacher  bulb get dim 200Watt!
https://www.youtube.com/watch?v=jjCbF9YjB4Q
the effect is counterproductive moreover, when disconnected Kacher it and so these bulbs are lit with the same push-pull with the same power ;D
anyone know what this is about?
This person says he has a different opinion on the scheme which gave Ruslan but what he just really wants to show?
AlienGrey
Quote from: Tomtech29 on January 22, 2016, 05:32:07 AM
Hi.
Hi thats interesting I tried it with an ordinary toroid but didn't get much back just an over heating transformer, but what happens if you reduce the current with a very low value resister through the thick feed back loop ?
GeoFusion
Hi Guyz. ;)
Nick,
I saw your pic/ setup :)  and the mediator you have wound, reason why its maybe dimming is
because it's not resonating with the bifilar coil on the grenade with the cap in series and to be just sure if connections are good.
Yes, try to find that 1 1/2 inch toroid, see if there is any difference.
You will need a tunable  circuit to find resonating point with the cap
you have connected you need to see if you can light a small bulb only using 3T coil. as test. without 28T.
Yes Akula/ Ruslan and especially Dally used their cores as mediator, Akula used his 28T as output to kacher.
same as how Sergey replicated his recently. same connections.
The URFA setup is new, has alot of new fields to explore still.
Dog-One,
Yes the schema is very simple, yet easy to read and replicate if you take time, the computer generated one
is very nicely done, makes it easy to build the boards that way.
Yeah, saw same minor oddness in schema too, but there you see in his vid which you have now in downloading the torrent,
he shows the schematic of current setup.  yea, the older handraw is slightly different, but hey he is experimenting
to see which one is best :).
yes his simplicity makes it easy to set things up. Takes just a bit of time.
now I know there needs to be a sharing connection within the circuit (mediator) and Yoke also.
Well massive heatsinks for sure because of massive loading that occurs at output.
takes alot of stress especially for Fets and Diodes.
yes, most likely this system is mixing,
But The Extra Ambient Radiant energy is what makes the torsion field large, because of the tesla ;).
Btw that SparkGap you saw, is strait to ground at the other end after spark. I think it's a tuning but at the same time just a Indicator.
  John.K1,
well for what I know in the beginning it's not OU yet untill it's propperly tuned and with ground connected :)
but for sure we should never forget that this system is using ambient energy for
multiplication. because of Tesla coil. ground is essential , it shows power at ground in one of my recordings.
Yoke is Inverter, yet it will give the two External components the agreement to mix.
Yet it will enhance the torsion field around the output coil
The spark seems to work as indicator when system is on,
Spark leads strait to ground after Sparkgap or it's a adjuster for output for sure :).
               Cheerz~
John.K1
Hi Geo.  Yes, but how do you catch that ambient energy??  How should  Tesla work to catch that "ambient energy"?  Tesla itself is not a Free energy or OU device. Who got the train of pulses  (in words of Ruslan- Pachky impulsov) on antenna, please present your picture and share your experience .
