0 Members and 149 Guests are viewing this topic.
John.K1
Quote from: T-1000 on January 28, 2016, 04:17:14 AM
You probably missed my  reply #11795 - http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg472504/#msg472504
That's interesting- When I copied the name ov the video " Kak eto rabotaet!" (in russian) and pasted to my YouTube, it didn't find it :( Any way good job you found it!
magpwr
Quote from: Tomtech29 on January 27, 2016, 11:01:41 AM
I'm curious about your work and especially this circuit LM I found a diagram ,
I do not have a replacement for the :K55TB9
what to put there?
These ICs probably would have found: 74HC14,CD4046,LM393,IR211?
You say you moved simulations Is it possible to check how stabilizes the frequency of Lc?
it would be great if you could say something about this scheme.
hi Tomtech29,
Please don't waste time on tesla transmitter and tesla receiver circuit of Akula.It isn't kapanadze and this device takes up the largest space in Akula room.
There was discussion about this i/c:K55TB9 it was 4029 or 4013 i can't fully recall. cmos definately which i can recall clearly.
The reason i am not a believer of Ruslan was because he was using pll.Base on my experiment it work merely lighting bulbs and efficiently lighting one if tune right.
If it's too good to be true.Please run away.
PWM generator did produce result which defy logic base on L/C resonance.
Last experiment conducted months back.I can't fully remember what value of capacitor i was using was it 0.47ufx2 in parallel wima or 4x0.33uf induction heater capacitors.
Anyhow the resonance at full brightness which i believe many of you will fall under this category is below 20khz if reasonable capacitor value is used.
For me the resonance was at 14.4xkhz which i clearly recall.But the abnormality was discovered at 28.8khz which the bulb was lit as well.But as part of experiment i merely switch off power to
my kacher-tesla transponder circuit using nanosecond generator(Oleg-Ruslan design 74HC132.But this was a single pulse back then).
This is where i discovered the effect similar to URFA.
Which means no kacher resulted no light.This part i was lost on how it tamper with L/C resonance.
I also discovered with or without 60watt bulb the power reading still stays at 54watt.Attempt to loopback failed as i tried to use a 90watt(90volts-240volts wide range) multi-voltage adapter set at
12volts to battery.This cause the bulb to flicker at 1 or 2 times per second.
Mistake learned not to use single nanosecond pulse base on old faked Ruslan oleg.I will use sergey approach to implement interrupter and the additional ability to position pulse something like the oleg's.
I need to assemble a robust pwm generator with 1.2kv SIC mosfet(For efficiency and low switching lost) to drive toroid(3 turns) with the previous assemble kapanadze coil in order to work on the latest circuit i am working on with the use of LM393 OR tlc272.
Back to square one.
I will still use my tesla transponder coil shown in my youtube since it's assembled for High "Q" in order to produce really notable current reading to Earth.
You will know outcome if you compare head to head typical tesla coil with my high 'Q' coil (base on observation/Reverse engineered version of Akula coil in yellow tape as zoomed in clearly pasted in my old posting).In both cases apply interrupter pulse and set to 100...200volts.
The coil spacing given between each winding is similar those classic coil winded on huge see through wooden bobbin.Can't remember the old word. ;D
If anyone bothered to download Sergey.He is using super high end audio wire OFC -Oxygen free copper as shown in the picture on the huge roll.
Akula did mention about this wire which will effect the length needed for kapanadze winding a long time ago.
I have enough copper wire run me entire home because of kapanadze .No plans for OFC.But i am jealous. :D :D :D
I have just completed testing sergey interrupter circuit as attached.
Take note of C1 original value 10nf (tested up to 19khz) changed to 1.5nf (test to over 30khz but not suitable for below 20khz.Take note of the interrupter pulse position) or leave it at around 6.8nf.Up to individual needs.I use 74HC132 instead of 74HC00.
Theory and practical aspect of sergey interrupter circuit is workable as intended.That's all.
x_name41
to increase the output power of these devices need to make a solid capacitor tank circuit (just like as powerful resonance induction heater). The reason is the so-called parameter "ESR". Incidentally do not need any PLL, only everything must be done accurately (as at settings of Tesla Transformer)
magpwr
Quote from: x_name41 on January 28, 2016, 09:17:16 AM
hi x_name41,
Are you operating this pwm circuit at two times the L/C resonances.
I wait for your reply.Thanks.
x_name41
Quote from: magpwr on January 28, 2016, 10:01:36 AM
hi x_name41,
depends on the settings, but the HC-MOS series their working frequency is up to several tens of megahertz
