0 Members and 58 Guests are viewing this topic.
John.K1
Hi T1000
I have listened that interview with Ruslan and It made me much more confused than before.  He says there to connect 26 turns directly to inductor??- also no capacitor as they kill the effect.  How is than connected three turnes if the inductor is connected to those 26?? He speaks about connecting of his yoke to some transformer (50Hz) ? and tune frequency  until you see some effect from your youke(ferite) - (this reminds me one of the last videos of Romanov)
The first end of the grenade is grounded (so does Tesla coil)
He was saying something to try output without diode bridge rectification? I didn't understood what he means to use high duty resistor at the output (no bulb).
Anyway, I got today my Gauger counter DP66-M  - Hope this will keeps me safe during my experimenting :)
Void
Quote from: John.K1 on February 23, 2016, 03:36:24 PM
Ha ha. Why am I not surprised? :) That is the thing about Ruslan. If Ruslan really understands what it takes
to make the Akula setup produce over unity, then he absolutely should be able to explain in just one paragraph
or two exactly and very clearly what the critical steps are to get the OU effect.  Instead Ruslan has been going on
and on in video after video and in some online tutorial sessions, and apparently still very little, if anything, is clear.
Very odd, to say the least. :) If Ruslan really does understand how to get OU out of these setups, then it would
seem that he is either deliberately giving people the run around for whatever reason, or Ruslan otherwise has some
serious issues. I can't see any other explanation for Ruslan's odd behavior to date.
Nice!
John.K1
Quote from: Void on February 23, 2016, 04:15:18 PM
Nice!
Hi Void- I had such a feeling from that interview ,he doesn't want to say his secret or he has non.  He actually didn't speak much about his device- he  was just taking of example of Kapanadze, Akula and Daly - :D  Also, many times when he was just half way to say something important , he just turned to something else. :D But one think is clear from what he says- do not hunt voltages- hunt for amperage!! -
Jeg
Hi John
It is clear for me that Ruslan doesn't want many people to replicate his device. That is the reason he continuously changes his direction lines. Anyway.
I finally made my new push pull board. It is the same as Acula's classic one but with better component arrangement on board. I noticed for first time this Gray zone that we were talking about. Thankfully i already knew the reason! ;)
T1000
Your pll idea would be good only in correcting push pull's frequency. If this is accompanied with high frequency correction so to keep the harmonic analogy between low and high frequency, then you make the Tesla coil method useless. This is because it is already tuned to a specific high frequency value (specific number of turns) which can not be altered. How are you thinking to deal with it? Even if you use a nanopulser instead of Tesla coil, again you deal with the same problem as nanopulser needs again a specific length of coil for using it with specific triggering frequency. Do i miss something?
Hoppy
Quote from: John.K1 on February 23, 2016, 04:51:31 PM
Indeed but making sure the power supply is disconnected first.  ;)
