0 Members and 341 Guests are viewing this topic.
skywalker66
Quote from: nelsonrochaa on March 27, 2016, 10:49:28 AM
The same happens in Tesla  time , with other people trying  to contradict what he say and show, until we reach their last years inclosure in a room  .
Good luck to everyone .
Nelson, I only hope you will not end up enclosed in your room because us, ignorant people, do you ?.  :o  ;D
It will be very sad.  :(
Good luck with your very private whatever you do.
skywalker66
Quote from: verpies on March 27, 2016, 11:01:37 PM
If you'd like to play this way, the vacuum chamber tank would have to be huge compared to the size of the coil in order not to introduce any losses in its proximity.
The wire should be silver, all right, but not a solid wire.  Instead, i should be a fine Litz wire.
This article refers to it as "current pushing" or "current bunching" but EEs often refer to it as the "skin effect" and "proximity effect".
I just kidding .  :)
I wanted just a damn kacher, whatever Q it have.
T-1000
The problem of most people is try to copy other circuits (akula , Ruslan Kapanadze )  without understand the real meaning of what is Tesla work .
Tesla left so many important information, and even that seems so few people are able to understand that, because some people in that forum with their blalala only INDUCE confusion in head of people .
But its ok,  the time will give me reason for sure , and i'm not concerned with the people that try trolling with their books and theories and attacks .
Even Moray feel that oppression by the gurus of their time and only humanity loose with that , but i will not follow the same path trying to probe something that so few are able to understand .
I wish that people think about my words and stop to try find every time something like :
is Fake !
To that people so "clever"  we only see one thing in their works  :
Fake or not seems unable to reproduce the same "illusion".
Just ignore trolling and attacks and please keep focused ;)
Do you have any comments on concept diagram I shared? Maybe add some valuable information to it?
Cheers!
skywalker66
Quote from: forest on March 27, 2016, 02:02:32 PM
No, just use a schematic box . I'm interested only in coils and not sure if I understood. Looks like Katcher when secondary is not grounded but connected to the primary so it act as a antenna. Would be nice also to learn how to make capacitor disruptive discharge with open coil as primary (if I understood correctly)
He most likely use a SEC exciter by Ronald R. Stiffler. See schematics attached.
Not so clever.  He also copied others ideas.  :-[
Jeg
Quote from: skywalker66 on March 26, 2016, 08:07:09 PM
That coil is intended as part of Ruslan device - kacher coil. Indeed that kacer wire length have 1/2 length of the grenade. It look longer because is spaced - it has 20.7cm.
Grenade wire length = 38.8M , house electric wire, multi stranded, cross-section 2.5mm2
Kacer wire lenght = 19.4M, 0.88mm diameter;
Nice and correct calculations. It is just that when you'll attach your antenna, your frequency will go down a lot and you 'll need to unwind again almost the half of your coil. This antenna is very "heavy" for high frequency targets like 1.5MHz and above.
