0 Members and 236 Guests are viewing this topic.
T-1000
Quote from: NickZ on April 04, 2016, 09:20:59 AM
   T-1000:  Two loops? Or, two different circuits, not loops?
As loops refers normally to a feed-back loop when the word loop is mentioned.
Yet, the number (2, capacitive loop) is still working by inductance. Not capacitively.  How is this NOT working inductively then? As it seams like the Kacher circuit is working by inductance like a normal Kacher circuits. Primary to secondary by inductive coupleling? OR, is it just the Kacher's output that is capacitively acting on the grenade's inductor coil.  Or what?
Is there a cancellation of inductance in the system in general, or not? As even the grenade coil has induction cancellation if those counter wound turns are actually working for that purpose, such as the schematics are showing.
The terminology I used may be not very accurate. From the Tesla coil perspective the grenade coil is just another plate of sandwiched capacitor which goes to the ground. Any load on grenade coil will not affect Tesla coil. I had same approach back in 2010 in experiments with Caduceus coil where the secondary was as another capacitor plate for the flyback transformer. The current to drive it was provided by Avramenko plug in that case.
It may be hard to grasp in theory but in practice it is straight forward setup.
Cheers!
Hoppy
   MenofFather: Thanks for your reply.  So, we still need to find out how this is all possible for a simple Kacher circuit to run all those things for hours. Very important thing to know, as a first step towards the direction of self running.
   He bought the circuit?  Ok, then. Anyway to know from where or from who came this secret circuit?
We certainly do! This is the most interesting setup I've seen to date because if its real (which of course I very much doubt), then its probably very close to how the Kapanadze devices work and shows the apparent 'its so simple you'll laugh' simplicity. The only difference being that the Kapanadze battery supply is hidden.
GeoFusion
Hi There  ;)
All
Well I do see a lot of confusion going on the forum but I have some important stuff to share with sins
it's over the net already but helping to view it ;)
See the kacher antenna + grenade + Inductor Bifi  as Capacitor plates. ;)
I attached a Complete Scheme of Alexee Sergey with PCB board. There are new Schema's in it to be viewed!
This is the latest of the guy with Kacher System outputing Kw's.
https://www.youtube.com/watch?v=zrvAvp_dmlU
He has finally shown it running without battery :)!
Using Power Supply which looks like from a laptop...  so no more battery and no ground  ;D
Ground is simply a plate within coiling tube ( Aluminium maybe ) but it could be how you connect it up.
all setups are different from each other.
Enjoy the video and Files.//  :)
                     Cheerz~
NickZ
  Geo:
  Thanks for posting that link to the new video.  It was as I said, not hard to self loop, once that kind of output is obtained.
However, it does not put out as much current, or whatever it puts out, as when running from the car battery.
  Nor from whatever hidden battery that only Hoppy can see on the TK devices, and all other devices, as well.
   Much confusion...  Yes, there's plenty of that, but not for long.
   I could not open the rar file that you posted.
GeoFusion
       Nick,
Do you have Winrar program?
http://www.rarlab.com/download.htm
use that to open it.
Download correct one to your pc/ laptop and install.
All .rar files can be opened after
I will make time on this simple system with kacher and secondary as this guy has :).
but will continue on the Ruslan Akula first maybe after that will do some experimentation on the setup
we saw on youtube and hopefully to figure out how it's all hooked up.
Cheerz~
