0 Members and 320 Guests are viewing this topic.
NickZ
  Eric mentions Tesla, all the time, but Tesla was not trying to obtain energy from (man made) radio station signals.
But, from the Aether, instead.
  Big difference,  as far as I'm concerned.
   Poma's device needs no Earth ground line to produce 2000- 4000 volts...   If true.
   EDIT:  Um... sorry I meant WATTS, not volts. You can easily get 2000v just by using a 1v battery and a oscillator circuit Exciter/ Kacher circuit.  But, 2000- 4000 watts from a Kacher set up?
   Geo:  Do you think that the "Sumator" in Poma's circuit is doing the same function as your "mediator" coil?  Or not?
   Anything new and exciting with your Ruslan device?
SeaMonkey
Good point Nick.
Tesla's work in Colorado confirmed that there was a
tremendous source of energy available in the Earth's
atmosphere and that a very high voltage stimulator-
collector apparatus was needed to tap into this
energy which was freely available.
The nature of the Ionospheric Capacitor and the
Vertical Voltage Gradient of the atmosphere is now
better understood and we now have a clearer idea of
what Tesla meant by "the Aether."
The amount of energy is so enormous that at present
there is not yet any practical way to tap into it safely.
It is the same sort of problem as would be encountered
in trying to harness the energy of a Lightning Bolt.
In fact, there are reports of some experimenters having
stimulated a nearby lightning bolt coming out of the blue.
If true, what is one to think?
AlienGrey
Ok let's have a look at the Grenade coil ok here Ruslan shows one of his grenade tear downs on how to wind it in it, he measures it's inductance with his meter he shows it's approx 240uh.
https://www.youtube.com/watch?v=bedLP_SOHoo
When i try it on a one I wound with cheap 7strand 2.5mm trunking wire it's about 150 uh with an air core, I asked Itsu for a reading of his device and believe he gave approx 160uh. I have not yet tried winding it with multistrand flexible wire as yet so I can't comment on that and i don't know what cable Itsu used in his device.
However if i insert a pole mount of 20 ring ferrox  ring cores mounted on a PVC 15 mm pipe into the centre of my test grenade coil I get approx 240 uh ;)
Something funny going on ? well you have the evidence as you can test your own device yourself.
NickZ
   Even when just using the Kacher on my Ruslan rep, to light incandescent bulbs, I use ferrite pieces inside of the grenade section of the pvc pipe, for further tuning. Not just inside of the Kacher secondary, but both. Otherwise I can't light 50 to 100w incandescent bulbs from just the Kacher's input very well.
  I got my new IRFP260N fets. Still waiting for the 18v zeners to come.
Jeg
Quote from: NickZ on June 27, 2016, 01:55:20 AM
  .... Not just inside of the Kacher secondary, but both.
You reminded me this..https://www.youtube.com/watch?v=4536mMgOjv8
instead of ferrites, a long Tesla like coil connecting both Katcher and Grenade.
