0 Members and 94 Guests are viewing this topic.
apecore
Quote from: AlienGrey on August 11, 2016, 07:41:09 PM
Have a look at this little gem then !
https://www.youtube.com/watch?v=vDp7bH0G7XA
AG,
Do you know if there is someone who also wants to replicate this device? Or is there somwhere a forum active?
It is quit clear in the video how al is connected etc.
Only the black ring what is lying on the neon transformer is something i don't reconize?...  It look like a ferrite ring?
Thank you in advance
NickZ
  There is an ongoing thread at Energetic Forum where they are replicating some versions of the Don Smith devices.
  But, the DS replication in that last post that AG linked to is rather old. Not sure if the flickering lights, were OU, or not. Or if could self run.
  Here:  http://www.energeticforum.com/renewable-energy/20533-reproducing-don-smith-effect-2.html
   apecore: You should try to obtain the Tv yoke, not a toroid core.  Tv repair shops may still have some around, or buy an old junk tv and take the yoke out yourself, like I've done. The yokes were made for running at about 15kHz, or so. And are bigger than that toroid you are using.
   The yoke cores that I use are 85mm wide, by 45mm tall, or even a little bigger.
   Just connect a regular 25w incandescent bulb to the grenade output coil, without anything else connected, and see what you can get at the bulb(s), from just the Kacher's output.
  If I disconnect the yoke coil (the cap and 3 turns coil) to the inductor, while the Kacher is running, the bulb brightness decreases at the grenade's output bulb, but, it is there still at about 80% brightness, left even without the inductor working.
   So, I think that my tuning is not so bad, and may just need some minor adjustments to reach resonance.
I have seen the amplification effect several times now.
   Thanks for the pics, and good luck with your push-pull driver.
   I am ordering more components tomorrow
AlienGrey
Quote from: apecore on August 12, 2016, 04:44:24 PM
AG,
If you look closer at the core former winding I think you might find it has an inner winding my guess it would be tuned to the full wave or it could be split in too ie 1/2 CW the other 1/2 CCW and the there is the circuit to drive it, but who knows ?
apecore
Quote from: AlienGrey on August 13, 2016, 08:40:41 AM
AG
I think it is similar to the DS setup..
Inmer coil 1/4 coil length and secundair cw and ccw...but could even be 1/2
Difference is that the single bulbs are connected.....perhaps used as LC load ....(this is new relatedto the conventional DS setup).
There are more capacitive adjustmenrs also in place.
1/4 or 1/2 wave is something to experinent with..
AG.....you don't know where to find more info to get?
verpies
Quote from: apecore on August 12, 2016, 04:37:53 PM
I ordered at Farnell but discovered that TME is even 50% cheaper on a lot of components
Don't forget to check http://rs-components.com
