0 Members and 127 Guests are viewing this topic.
apecore
Quote from: AlienGrey on September 03, 2016, 06:54:47 AM
Apecor   part of Naill circuit if your interested.
Regards AG
Thank youu AG..
Sure i m interested
NickZ
   apecore:
   I connected the output of the load of bulbs to the 0.47uf capacitor. Also with the 28t coil yoke coil connected to the grenade's output coil.
  The results:
   The lights (3  120v, 100w bulbs) light fairly bright, but not as bright as when on the output of the grenade coil.
   However when connecting the full bridge which feeds the Kacher's input to the 3 turns coil, it kills the lights.
   I reversed the polarity of the bridge at the cap, still no difference, no lights.  I don't know why, as there is enough power at the cap to run the Kacher circuit, also, but when I do it kills the lights. Even it's only a single 25 watt bulb on at the time. Plus the Kacher circuit will NOT run off of the 3 turns coil/capacitor connections, either.
   So, similar results?
AlienGrey
Quote from: NickZ on September 03, 2016, 11:48:45 AM
   apecore:
  The results:
I hate to see someone struggle but how is the rest of it wired are you sure it's right ??  and rumour has it you won't get full brightness out of putting bulbs across the .47 uf, but you need an extra .9uf across the 0.47uf as well.
AG
NickZ
  Putting more caps onto the 3 turns coil/capacitor only further dims the output.
  It's no struggle just part of the tuning process.  I never expected it to be easy.
Hoppy
Quote from: NickZ on September 03, 2016, 02:01:05 PM
Nick,
Geo also has a motor cap across the grenade winding. You might also need to adjust duty cycle according to Geo.
