0 Members and 665 Guests are viewing this topic.
Tomtech29
Quote from: NickZ on September 04, 2016, 09:00:54 PM
    apecore:
    Ok, thanks for drawing that diagram up. That's what was needed, and I'm working on it connecting it up that way.
I hope Geo draws up something similar of his device, so we can all get on the same page.
    If I place diodes like the 3 amp ones that I have anywhere on the induction circuit, they go up in smoke in no time.
I'm still looking for the MUR1530 rectifier diodes, or something similar to the diodes that you are using.
     I also find that a choke is needed for sure,  next to rectifier. It drops the input to the Kacher though, and it also gets hot, but can take it better than the diodes.
   Tomtech:  It's good to see you on the bench... again.
   I'm finding something similar. And once that happens I can't control the frequency, it seams to lock on somehow.
   If you are seeing the load stay the same, it would be a good place to connect the PS for looping back from that point.
                       Good luck with your set up.
Thanks Nickz.
https://www.youtube.com/watch?v=feVm9qPJTMI
Effects may be slightly different in layout Mazzilli and difficult to achieve even do not know if it has any significance in achieving
- trying to go that way,and see if it changes anything
- there is no need to dress to get a high efficiency heaters important is the effect of the amplifier try to find out where Geo.
I only question is where did you get this ring ferrite to perform mediator,I can buy it on ebay?
NickZ
   Tomtech:
   Thanks for sharing the video.
    I don't know which "mediator" you mean.  As I used a big 3 inch yoke for the mediator previously from a tv, but I also tried another smaller mediator coil, like Geo suggested, such as the one below. Which probably came from a PS, or similar.
   The second picture was when I was using the 12v yoke core, as the mediator.  Other chokes are needed also, as the yoke core when used as the mediator by itself lets too much current through to the ZVS circuit. I had previously made the mistake of not using my other chokes along with the yoke mediator, and burnt up the Mazilli.
   Last night after midnight I had some luck with my set up, when connecting it up like apecore's diagram.  But, I'm still working on it today and I will report back, soon. However,  I finally got the Kacher running off of the rectifier voltage of the 28t coil, without my rectifier diodes going up in smoke.
   Some interesting effects to be seen... so far.
   Tomtech, I like your commercial rectifiers, and I'm trying to get something similar, or build one myself using MUR3060 diodes.
   I also liked your voltage/amp meter. Can you tell me where you got it from.
NickZ
   In this video (below) I'm running the Kacher off of the 28t coil through a rectifier. 24v input from the PS, only to the ZVS crt.
   Single 100w bulb as the load.  Actual lumin increase with the Kacher on, about 2 to 3 times brighter.
   Connections similar to apecores diagram, as close as I can do for now. As my rectifiers diodes are good for boiling water for my coffee, as more heat is released, than light. However, the diodes are running a bit cooler now, with the addition of the 100w bulb on the 0.47uf WIMA cap.
   Watch the video when I turn on the Kacher,  to see the bulb brightness increase before the camera compensation dims the additional influence provided to the bulb, from the Kacher circuit.
   Comments, as always, are welcome.  Hoppy? This may not be OU, but getting there, perhaps.
I'm not as excited as Geo, yet.  "That will come"...
    https://www.youtube.com/watch?v=LQFJxiPomwc
Hoppy
Quote from: NickZ on September 05, 2016, 02:21:58 PM
Good progress Nick. What voltage do you have across the bulb at is brightest? Also what is the rated wattage of the bulb?
Tomtech29
Quote from: Hoppy on September 05, 2016, 02:47:13 PM
with all due respect I ask myself what you would like to measure it "Voltage " that you do not know that there is such a high voltage and frequency of the digital meters freak electric arc  hisses and whistling I'd be has provided the tilt of the analog voltmeter coil and pointer.
- seriously as he plugged 60V to the circuit Tesla oo hair stand on end :D lot on the air happens.
Nickz please be careful  adventurers keep going.
I do not have this NPN transistor and wonder of buying and ferrite such a large-scale (green).
You asked about the display and the diode bridge?  You can be found on Ebay.
as already mentioned : Ruslan under Kacher  heats up and burns most of. sooner or later! (He mentioned the low current mA) and several kilovolts. That's what I've heard I tested it on some recovered from the inverter.
and many of these also fast in the housing are recommended burned.
- for now peeps one of the people who is trying to rectify this entire process in the coil and the waves of modulation might be able to make something out of it.
in his spare time something I'll load
