0 Members and 56 Guests are viewing this topic.
NickZ
  apecore:
  Thanks for your tests.
  From what I can see on your video, (which is still a little confusing to me), is that the way that you have your system set up, is not working right.  If you connect the other two bulbs, the tests would possibly be more accurate, as running a single 100w bulb on 24v 5 amps, (120w) and only dimly lighting the one bulb, including using the Kacher's output effect. It's hard to evaluate your bulbs output, as we can't really see it on the video. Maybe you can turn the bulb so that we can see the light, instead of pointing it up.
   But, I do understand that you are now testing according to Hoppy's suggestions.
   What possibly your video is showing is that there is no sync between the induction circuits, if you are just taking the output from the 28t coil, and showing no effect (or a negative effect) when connecting the 3t coil.  I can practically light a 100w to that same degree, just from the Kacher's input, with no induction circuit turned on.
   Please load the other two bulbs, connected to the 3t coil, and let me know what happens. Also your inductor is wound with three layers, and going all the way across to the end of the grenade's ouput coil, and not the 1/2 way point on the former tube. Try to make a tap at the two layers point on the inductor to see if there is any difference.
Ruslan does not use three layers on the inductor coil, nor Akula.
   Placing your hand near the antenna coil, is showing a brightning of the bulb. This to me also indicates that the system is still not tuned for best performance, and that the hand near the coil creates a better degree of resonance. Although Geo was showing the same effect with hand movements. I believe that now that has also been corrected.  Although, I can be wrong concerning Geo's set up. And perhaps he can explain it better.
   Even though Hoppy thinks that adding more bulbs, and having a higher loading is not helping in increasing the "effect", that is not what I'm seeing, and showing. There is a reason that both Ruslan and Akula are using only high wattage bulbs, instead of many smaller wattage ones.  And impedance factor is only one reason.
   One more thing. Try like Hoppy is suggesting, to use your batteries, only. And connect both the Kacher's emitter as well as the grenade (starting or ending connections) to the SAME Earth ground. Also a connection from that same ground to the 0.47uf capacitor. Try all different ways to skin this cat, and report back.
  Also, keeping in mind that connecting the scope's negative probe to the device will ground the HV to the AC grids ground, and this can affect things, as well.
   I hope that I haven't bored you with my suggestions.
   Happy tuning... and good luck to you.
apecore
Quote from: NickZ on September 13, 2016, 12:00:05 PM
  apecore:
  From what I can see on your video, (which is still a little confusing to me), is that the wyay that you have your system set up, is not working right.  If you connect the other two bulbs, the tests would possibly be more accurate, as running a single 100w bulb on 24v 5 amps, (120w) and only dimly lighting the one bulb, including using the Kacher's output effect. It's hard to evaluate your bulbs output, as we can't really see it on the video. Maybe you can turn the bulb so that we can see the light, instead of pointing it up.
Nick,
These test were only mentioned to see werther kacher effect effects the push pull.
Thats why i did not tuned it at maximum performance.
But i agree with you as you mentioned about the bulb brightness...it is indeed one of the best summerdays here in the Netherlands at the moment...so i will it agaim tonight and trying to do it as you mentioned.
Maybe it is time for us and our 3 or 4 running systems to define some standards and connection details.....as wich we now know already how it performs at highest rate.
Greetings
Hoppy
Nick,
As part of these tests, can you please video demonstrate your 100W lamp running from the Kacher only but please show the current draw like Apecore does, so that a comparison can be made. The Kacher does of course induce current into the grenade and induction coils, so the power (volts x amps) available to the Kacher will make a lot of difference to how bright the bulb is lit without your ZVS running. If your Kacher is pulling considerably more current at the same supply voltage than apecore's, then clearly your bulb may well shine brighter than his. As I have pointed out to you several times, you must start measuring things and not just making assumptions soley based on comparative bulb brightness between different systems.
T-1000
Quote from: Tomtech29 on September 11, 2016, 03:58:18 PM
you remember the old stuff:
https://www.youtube.com/watch?v=4ZqHtsc537Y&t=0s
someone repeated the same level I mean just for the effect of these 1260 Watt In this construction  of the coil?
probably have someone tell me that I clung to ...
but most of the Russian reps replicas effects are wasted tests on 500 Watt why not show more ?
and without the effect of strengthening Ou.
In regards to old stuff there is Russian video where akula explained how to catch the effect and how to gain amps on the output with the tuned HV discharge pulse trains:
https://www.youtube.com/watch?v=4hbBr26CwAE
It would be very useful if someone would make English transcript of that video... ;)
Cheers!
NickZ
  Please check my last post, as I made another suggestion on it.
  apecore:  If you don't tune your system first, the effects that you are seeing may just be the Kacher bringing up the output to only what the 28t coil circuit will do by itself, (when it's fully tuned), but not really "amplifying" it.
At least, That's what I've noticed.
  Also, look for the magnetite magnets, to improve the overall yoke's output, if you can. They can make big difference in the output. Possibly any strong magnets will work.
   Glad to hear that you're having good weather there.
   Hoppy:  There is nothing that I "must" do.
That only applies to what you think that YOU must do.  I do what I want to do,  not what I must do.
   Here's is an older video showing what my Kacher can do (by itself), running on 24v, and approximately 2 amps.
  Kacher partially lighting a 110v, 100 watt incandescent bulb. - YouTube
   At the moment my Kacher is connected and running from to the rectified voltage coming from the 28t coil, not from PS, as in the video above, nor from a battery.  I've explained to you that the Kacher's input voltage from the induction system is 20v, not 24v as with the PS in the video.  I'm trying to provide you with what you asked for, when I can, and in my own way.
   Geo has blown us all away, without any test gear at all. So, perhaps we can learn something from his methods, as he is not being distracted by "readings". Or focusing on matching resonant points by using a scope.  Each to his own, way.
  "Diversity is the spice of life".  Or so you mentioned, remember?
