0 Members and 367 Guests are viewing this topic.
TheCell
Quote from: Enjoykin2017 on October 03, 2016, 01:51:19 PM
Ok people  -now back to technical aspects
Very interesting schematic came from Realstrannik member DELAMORTO
His variant is below. Shortly - accelerating "soft" electrons from inverter with "hard" electons from HV AC transformer (not fly back because FBack has several HV-diodes at secondary side and DC output). We need HV AC output.
Very interesting schematic that pushed me to start reading again very interesting book abut "soft and hard electrons" and masking hard electrons by soft electrons.
The book name is Cater, Joseph - The Awesome Life Force -
Take a look at this schematic and try to study it. Special interest belong to cylindrical  cylindrical asymmetric HV capacitor and steady HV E-field in it. Take a thought.
Reg.
Enjoykin
Now this seems to be a sr193 variant.
There are many 'operation-modes' of the components included:
The audio amp with the pnp npn transistor can be fed with sine signal or a pulsed signal (or what you call a meander)
Tiger mentioned not to use a sine, because the core should be driven into saturation (where the magic should happen :)
The core material itself may be of importance.
I have got flybacks whithout diodes , mazilli circuit lying around .
The HV Part could consist of a coil wound directly on the ferite core , with the copper rod in the middle.
On top of that the modulation winding and the pickup winding where you connect your bulb. All that simple.
The circuit is like a 12V inverter with a HV plates / coils included.
But amps on the modulation part (50Hz) do not drop when HV is applied. (Spark Gap included)
So you could reveal the operation parameters / construction details / materials that are crucial for getting the OU result,
if you can / would.
Enjoykin2017
Quote from: TheCell on October 03, 2016, 02:56:55 PM
if you can / would.
Hello TheCell !!
This schematic belong to DELAMORTO not SR so I think should be analysed carefully. In a sense Laboratory tested with different setups. Yes you have right - this circuit have many operation-modes and because it is hard to be examined and tunned.
For inverter circuit i am suggesting 200 Amps welder schematic i was posted some time ago. Of course researcher should use only inverter part with two strong weling IGBT transistors and opto-couplers. This module works mainly in short-circuit regime with hard active and reactive loads and is excellent for BTG testing conditions.
Driving inverter should be done with quality signal generator with different signal shapes and presets.
Asymmetric non-linear HV capacitor should be made from copper or aluminium sheets with cutted slot to avoid short-circuited turns. I think both coils should be in inner space of capacitor so the outer plate of capacitor need be on top.
Spark-Gap should be fine adjustable. The best variant is vacuum type spak-gap with adjustable electrode distance. Also U-shape bar permanent magnet could be used around the spark gap for fastest arc disrupting.
About ferrites i think BTG ferrites must be met to obtain rectangular or square hysteresis loops. It means should work in high saturation mode like bistable elements. Take a look for western ferrite manufacturers for properly type.
Correct operation parameters nobody knows. They should be rediscovered again.  Construction details and materials every one use what can obtain from his sourcers. I think people here have a lot experience in that.
Enjoykin2017
SteveP
I have already gave a lot of facts for those which are open mind and have good will to understand.
My advice for you: Dont read Official Main Stream Teasers and dont public their Idiotic Conclusions because they had lost connections with natural reality and dont know nothing except playing their abstruct mathematical childish games in their imaginary PSY SPACES !! Examples like imaginary numbers -1, and imaginary complex space calculatons WHICH DOES NOT EXIST IN NATURE !!
YES MATHER NATURE IS NOT SO STUPID, MAKING SUCH ABSURDS AND RISE THAT ILLOGICAL RUBBISH TO HIGHEST "TAMPLE OF TRUTH" !!
What more to say about Official Main Stream Science which is hyper top attainment HORSE POWER UNIT for all. So the implicit inference is this: OFFICIAL HORSE SCIENCE NEED HORSES FOR EVERYDAY COMFORTABLE EXISTENCE !! Isnt it ?  ;D
I think YES !!  :D
SteveP  - people here and everywhere does need any OSPV - Official Science PSY Viruses - but workable principles for own home BT Generator/s. So 5-10KWatts/day free electricity and some heat for domestics life. Nothing more - nothing else.  :D
I dont know the reason why you have "abandoned" working 1KWatt "STAR" BTG device or maybe you have perfected it and using undercover for main power source for your domestic life ??  :o
You are one of several persons here who could made complex laboratory experiments and could give people new energy chance because you are ex NASA scientist and you have NASA range Fron end Laboratory in your house. If you are willing and ready helping pepole by obtaining working principles of free energy ferrite generators start your quest with translation and commenting at your level of understandings this old Russian scientist project about boosting sensitivity of ferrosonde magnetometers , using negative resistance region under controled conditions.  :)
I have already posted scans on Graham Gunderson thread and now I will repost again for all and specially for SteveP. Parallel with your translating , you should make a lot of practical experimental works using your network analysers and other front end scientific equipment - i have seen at yours home laboratory.  :)
Reg.
Enjoykin
AlienGrey
I believe you Enjoykin I have seen much in my life and conversed with many skollars ;)
A G
Enjoykin2017
Quote from: AlienGrey on October 04, 2016, 08:58:41 AM
A G
Thank you A G !  :)
