0 Members and 166 Guests are viewing this topic.
PolaczekCebulaczek
I've read a lot about Tesla work, studied his patents, great inventor. Tesla did work on ether energy but find nothing in that department, no proof, no patents ,nothing!( don't tell me about fake free electric car story.) but perhaps he was ahead of his time, does not have access to high precision electronic devices that we have now.Time will tell if there is something in ether/cosmic energy.
One thing bothers me, if Tariel is real and "so simple you will laugh" so why we struggle with such complicated devices and hard to tune? it seems that Tariel knows simple method and he is living in fear because of that, just look at his older devices, how much electronic components could be in green, aqa box? plus feedback parts and minus decoy parts, come on!
dewetw
Very cool link. Some thing else to see an actual newspaper from the 1800's. Languages was a bit different back then. I always wounder what Tesla would have been able to achieve if he were to live in these times.
I am almost done constructing the signal generating circuit. One chip to generate push-pull in phase and 180deg out of phase with duty cycle adjust, variable pulse offset and and pulse width with phase select for control of tesla HV HF generator and also the tesla generator with pulsed mode or continues mode. Will make a video tomorrow and post the link.
NickZ
   Ok, then believe what you will.
   Perhaps this is why no one has anything to show for it. You don't believe it can even exist. Not one person has actually replicated a Kapandze device, nor the Akula/Ruslan devices, as is shown in the video, nor schematics. Perhaps this is why, no one has gotten anywhere with any of this.
   I've got better things to do, than to try to guide anyone that thinks that they know better. Sorry I even mention it.
   Just keep trying to burn material things up like ferrite or copper wires, to extract energy from. Let us know how it goes...
   So, you think that Tesla, our greatest inventor and scientist didn't know what he was talking about???
   https://search.yahoo.com/yhs/search?p=Tesla+Aether+and+cosmic+energy&ei=UTF-8&hspart=mozilla&hsimp=yhs-002
nelsonrochaa
Quote from: NickZ on October 09, 2016, 03:31:42 PM
  If that were the case, then just tune the device for lower frequency. But, that it not the case, that is just one of the effects of adding a ground line. And is why one needs to TUNE the device with the ground line attached.
  If you've never built any of these devices, you'll only be guessing at best.
  They have never said that they need an earth ground line just to lower the frequency.
If you think that that is not so, then please show some proof of that.
  The antenna is not "make the antenna longer".  I don't know what you mean by that, but, the ground line is made as long as the grenade's output coil, 37.5 to 40 meters long, depending on the exact size of the grenade's output coil.
They have not made the antenna coil longer, either. The antenna coil is made and wound using six turns, most always. Although it may also work using more or less turns. That I don't know, as I've only followed the instructions, as seen on their videos, and schematics.
Hi Nick , hope you are well,
about ground :
ground connection could be "recreated"  with a long wire connected to a metal surface without have any real ground connection , but in other hand the collection of charges will be higher too, if  is used  a real ground,  they will acts like a bigger plate with bigger  surface creating a bigger unbalance of negative charges  in relation to the other plate  , and is the reason to not need long Antenna on that system, because the charges between them must be unbalance.
Connecting one plate of a capacitor to the ground we will get a current flowing in this circuit because electrons from ground plate will be pumped creating excess of electrons in relation to  other plate that will become with deficit of them in other side , creating a potential difference between them.
The Grenade acts like a capacitor plate charged by the Tesla coil  , with a high electric field kick provided by kacher circuit and that create the process to make the pump effect . So , higher the charges collected  higher the current that will flow between ground and grenade lowering the power need on the input system. That process will be where the extra "Power"  or amplification is extracted, but is not the only theme to think in this type of system 😉.
But like many months ago i say , is not the only way to make this effect happens if this process is full understand, and that should be the reason to kapanadze say  their circuit is "so simple you will laugh" .
I see in your lasts answers you are a bit nervous when give your answers, but you should learn that sometimes without any warning our brain could receive a click and everthing start make sense , and to that happen we should make first  sometimes the most basic tests;  could be basic but important to clarify our ideias  about some particular subject .
You want a self-runner circuit , so you should think what is need to that happens .
Any underunity device should be a self runner ? You know that it will not happen ,  need find a way to cancel some of the causes to most circuit work underunity , the losses . That is the first goal that should be achive before  think in a self-runner system , otherwise like you say already to other guys even after só many posts nowone will show nothing .
Wish you best luck .
Nelson Rocha
