0 Members and 194 Guests are viewing this topic.
Hoppy
Quote from: AlienGrey on November 02, 2016, 08:39:59 PM
Hoppy
why don't you ask someone who has a working device to show what happens when the Tesla coil /Katcher is running and no grenade MosFets and power, then no katcher but grenade running and the same with ground and then without, assuming they agree, and see what you get
A G
Alien,
I don't need to do that. Its common sense to observe waveforms and do measurements to understand how a particular circuit / device functions. Its up to the individual to do that if they so wish.
AlienGrey
Quote from: verpies on November 02, 2016, 02:56:04 PM
In a nuthshell, DSRD pulse generators are able to generate a very dense frequency spectrum. Tesla coils cannot do that.
See here for an English description, maybe that will help you understand it.
Verpies if the thing is just producing a pile of blips one after the other won't it be capable of pliping over flyback pulses in a given time frame assuming it's producing them and the other thing won't it need to be in phase ;) ?
Also look at Adrian's device his isn't that complicated. Kapandarze said on at least one video the two wave forms have to be in phase (not overlapping) .
A G
AlienGrey
Quote from: Hoppy on November 03, 2016, 04:17:55 AM
Alien,
I don't need to do that. It's common sense to observe waveforms and do measurements to understand how a particular circuit / device functions. Its up to the individual to do that if they so wish.
with respect Hoppy I don't see you observing or doing what you ask others, no offense intended.
Ok Hoppy if I was building a superhet radio IF strip why would I connect a light bulb to the local oscillator /mixer section  to convince myself it was working when i can get an output from the demodulated section a hell of a lot easier and see what's going on ? We are not all commercial entrappers ;) we are experimenting amateurs with limited resources and equipment, well most of us. ;) :) .
AlienGrey
Hoppy, this is a chattering relay driven with 5v and 22ma, i'm looking at the return pulse from the hot end of the coil with a 100 x scope probe and a digital scope and it's almost overloading the scopes capabilities as it's starting to clip the peaks of the waveform, but as soon as I add an earth to the neg end of the Diode all the pulses appear to disappear and the cap charges up with a massive amount of energy.
However you can see the type of waveform works best if you want to blow your scope up feel free, but you have enough info here to get you device off the ground. Good look with your experimenting ! ;)
PS Maplin camera ;)
verpies
Quote from: AlienGrey on November 03, 2016, 05:06:40 AM
Verpies if the thing is just producing a pile of blips one after the other won't it be capable of flipping over flyback pulses in a given time frame assuming it's producing them and the other thing won't it need to be in phase ;) ?
I don't know what role these nanopulses played in Dally's device described in the beginning of this thread, but I read some plausible theories (e.g. here).
I don't know what "flipping the flyback pulses" means or whether it is desired.  I don't know if nanopulses and flyback pulses are interchangeable in some sought after effect or if one is supposed to modify the other.
Also look at Adrian's device his isn't that complicated. Kapandarze said on at least one video the two wave forms have to be in phase (not overlapping).
Phase relationships are important but not in all scenarios.
Do we even have a complete schematic of the recent Adrian's device or its Modus Operandi  or at least its tunning instructions?
Does it even operate on the same principle as the Dally device that started this thread?
