0 Members and 321 Guests are viewing this topic.
verpies
Quote from: NickZ on November 18, 2016, 09:52:34 AM
Yes, and no.  The "effects" of the hand movement has nothing to do with it, it only shows that the devices can be affected by it,
'If the "effect" can be affected by the hand movement then it is wrong to write that it has nothing to do with it.
I am puzzled why you'd write that - perhaps you don't realize the impedance of a human body at HF and the way it can shape the fields of the Kacher.
mostly in a negative way, by disrupting the HV, HF signals from the Kacher circuit.
Away from optimum is not some intrinsic direction of the hand's influence.  It is a result of tuning the circuit for optimum energy transfer with the hand absent.  If you tune for the optimum with the hand present, then the absence of hand will seem "disrupt" it.  Anyway the word "disrupting" is highly subjective in this situation. "Altering" would be more appropriate.
The duty cycle and frequency controllers are what is responsible for tuning the device to run at the optimum running frequencies.
Yes, and these controllers should by the deliberate & sole determinants of the frequency, phase, amplitude and waveform shape - not some accidental HV HF interference with a hand inbetween.  That why immunizing these controllers (including the gate circuits) from interference is a step in the right direction.  If you want to add the frequency, phase HV-sensing from the Kacher then it should be done with a deliberate, well controlled circuit ...not this accidental interference you have now.
Hoppy
Quote from: NickZ on November 18, 2016, 09:08:05 AM
So your logic may be good for you, but.... you are not one of those that has what it takes to discover the secret of its operation.
Agreed. That's why I'm sitting back waiting for you and Geo to show the way. When will you be looping-back?
NickZ
 I don't know yet I need some time, maybe Geo can do this first as he has the equipment and the batteries to to test with. I don't, as yet. And I'm still working on improving the output, as it's only 60v or so, and that is not high enough.
GeoFusion
All,
Let me share some thought to this
The Effect,
Ions within the electro static field excited and pulled by telsa/Kacher/antenna that will merge ( go in phase)
with the resonant magnetic field of inductor which will create a higher output power combined out
within grenade in capacitive form. ( the receiver.. Grenade) All is still HF output.
But it also seems to be generating a good outpower within the inductor in my case.
Where or when is this extra Ionic energy coming in from the ambient backround?
The working of the tesla coil or a HV discharge pulse circuitry has to be understood to this especially if
when SparkGap is applied. SPIKES* nowadays ppl can do this by transistors.
Collapsing the field of HV HF or
better to say abrupt collapsing is what causes this energy to be called in,
remind the mind what a spark gap does on inductor.
Expand & Contract field. The Contracting part ( Collapsing of the field)
is where focus needs to come in and make sure your receiver is in resonance with what is transmitting
such as a tesla coil setup to receive all of it the moment it comes.
Some of them need Interrupter to do better work where it can be controlled by timing on demand.
That is when a circuit with more pulses can be created to create what we have seen on
Akula and Ruslan's Sergey's ...the train pulses. Multiple Collapsing in few moments.
Imagine what 1 pulse can do in comparison to multipule pusles for harvestation.
That is why they managed to create devices which can go even uptil 4KW and it makes sense for me now.
Hand over the Antenna or device is showing where your body can interact with the electric field of telsa
able to manipulate it and it does in fact lower or raise freq, Impedance.
I have seen this on scope. it looks like you could tune
this way but this is not the way. Might be a new one. It's like a disturbance with the flow of the Field and within it.
BUt this is not the effect. Effect is what I have written in first rows.
Imperfection is what is making the field so sensitive. It's like pushing or poking a bubble with air release
and when removing it fills up again with it.
It's beautiful if to visualize it all. makes to understand the unknown a bit better.
About self running, I do see only when it's stable enough it will,
for what I have now is It can let a other PSU 24V work, I have shown it but,
needs fine tweaks which will alow it to do so.
fine tuning is to my part now and also for more harvest.
      Cheerz guyz ~
conico
If inductor and grenade coil have one terminal on the ground , the effect of the hand is minimum.
If the coils are not on the ground, the effect of the hand is maximum, hand become something like the ground.
