0 Members and 316 Guests are viewing this topic.
Void
Quote from: AlienGrey on August 13, 2017, 09:46:43 AM
It is not disruptive...
AlienGrey, my comment was in regard to your insulting and rude comments to me and others here,
when there is just no need for that whatsoever. I have seen this same behavior from you on numerous
occasions here. If you want people to treat you respectfully, you need to treat them respectfully.
To be frank, many of the other comments you make here as well often do not make much sense, so that is
probably another reason why people often do not respond to you. Please stop the insults and spamming.
Thank you.
Void
Quote from: Hoppy on August 12, 2017, 08:01:43 AM
Yes, If these devices are genuine, then I too believe this is probably the key. I mentioned this along time back but have never been able to source a supply. Apparently some of the vintage 60's loudspeaker magnets and radio rod aerials had barium content.This is a primary reason why I stopped experimenting. Like Nick. I'm also concerned that the modus operandi might be NMR.
Hi Hoppy. I am still on the fence on the NMR thing.
Some demonstrations by some people seemed to suggest that something like that might
be the case, and then some other demonstrations by others seem to suggest otherwise. :)
There is also the possibility that some of what we have been seeing in different demos is
making use of different effects. ;D
Hoppy
Yes Void, I thnk that's quite possible.
Void
Hi Hoppy. What did you think of that guy Paiva's videos for which you
posted a link to his 2004 Kapanadze setup? I didn't see anything obviously
suspicious, although I didn't watch it super carefully. I am kind of suspicious because
he seems to have done other replication videos of other types of devices as well, but I suppose
it is at least possible. :)
Hoppy
Quote from: Void on August 13, 2017, 02:54:50 PM
Unlike most other claimants, Gerson displays a suspicious level of neatness in his builds. I reckon he is or would make a good model maker.  ;)
