0 Members and 367 Guests are viewing this topic.
stivep
Quote from: AlienGrey on January 15, 2018, 06:27:58 PM
Wesley believe it or not I have this very pic on my desk now pondering over to translate it or not, it's a strange phenomina Sir Richard Feynman talked about in a lecture.
No not this one the other one! But this one will explain it better 'if you can get it to work'  ;D
Thank you for your response Alien Grey.
The translation of pictures republished by me in my previous post, is marked with black characters.
There is something I hesitate to say and hesitate to publish  due to respect of being safe deposit box for quite few who decided to trust me.
That is why I mentioned possible date of publication at the  new date of Election  changed recently by Duma  to the day of Tzar Aggression and annexation of Crimea.
That would give him  reelection and next 6 years, that equals 18+6= 24 total of the  Tzar in power.
However subject in question is very much related to  my post from above and your response my friend.
I have checked this phenomena and it appears to be valid experience.
https://www.youtube.com/watch?v=Mn8TLBsR3r0 you may just watch from 8:00 minute
It doesn't matter how we excite it
(by, alphas, betas, telluric current, 9V battery or anything else.)
the only difference will be that with isotopes the  activation will be just randomly sporadic due to probability of decay in given time  frame   ( DeltaT)
The main point is to stimulate  Electrostatic Pump Phenomena .
However the higher the voltage the better.
(some educational material  is here however  read it just for  purpose of Education material   page 57
https://books.google.com/books?id=lXYll7rmYeYC&pg=PA57&dq=dielectric+response+in+variable+fields&hl=en&sa=X&ved=0ahUKEwjy2u7jy9vYAhUQSt8KHZYHBlgQ6AEIKTAA#v=onepage&q=dielectric%20response%20in%20variable%20fields&f=false   )
( attracting electrons due to high voltage potential - should be understood as just higher voltage potential than the ground)
Please place in search of this site  Electrostatic Pump Phenomena . and read the  answers.
one from the possible links is here ;
http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/21960/#.Wl153jdOm6s
http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/22515/#.Wl16fDdOm6
http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/22085/wap/
http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/22065/wap/
Wesley quote is interesting as transition from motors to electronics: http://overunity.com/12736/kapanadze-cousin-dally-free-energy/17490/#.Wl17xjdOm6s
-Please note  that above links are not the complete list  of all available
-Please note that publications have been made in different times and my experience with the concept of Electrostatic Pump Phenomena known as Electrostatic Pump concept was still work in progress.
As the interrupter,  (other names: key, manual or electronic switch, nanosecond  generator, and so on) we can use anything  depends how you build  such interrupter
Tariel used HV and Spark Gap more of it is here:   https://www.youtube.com/watch?v=WDcITQ7gtaI
Than he used impulse train from  Gas heating  unit more here: https://youtu.be/_YPVwfnvqw0?t=546
Some of  the secrets are here https://www.youtube.com/watch?v=YrRc-xieWjE
However it does not have to be exactly that.
Main point is to  have  Very high permeability of the core 2000 or more.
But it may work as well at 700
and high frequency  without distortion  bandwidth.
- note for Glen Transformer (look  at  at attached picture) was finally used with success !!!
So let's say                                   :      I use sinusoidal signal from 0 to100MHz and it will come at secondary winding  without distortion
but at it  also works with  square   :      I use  square    signal from  0 to100MHz and it will come at secondary winding  without distortion
That said should be understood that you do not need such bandwidth it is good to have from 0 to 35kHz.
- please note that it is good to have  microphone connected  say preamp and than, to oscilloscope to make sure that  Sub-audible  sound from the core is present if you do not hear  sound from 0 to 20kHz  out of the ferrite.
The advantage of nanosecond generator   is that created at the end HV / med V square/rectangular signal has two edges  the rise and the fall ( the AC components of  square impulse)
So you have two  points of stimulation in every   impulse instead of  sinusoidal that has two opposite. The up and the down of the period
Yes we can flip in rectifier or Gretz Bridge   the lower half and have them only on positive sides  however  it would not be  that rapid as  square/ rectangular one.
What is important to mention is THAT WHEN YOU LOOK AT THE COIL AT THE PICTURE THAN YOU SEE THIN LINE NEXT TO COIL DRAWING (look at picture below)
Try to compare it with  https://youtu.be/_YPVwfnvqw0?t=621 (  please note that at the day of publication of  that video my
drawing  might of been inaccurate  yet )
Wesley
Message for the trolls : Do not escalate the  situation, leave me alone.
If your brains can process this information please understand that escalation causes motion. Motion causes interaction and by that  "negative energy of response".
Due to your good behavior in regards to my last video publication I even have made  friendly move  by making  my last video private.
But we can have army of bloggers making hundreds of responses per day. You have  just 3 months so let it go. I might be kind to you too. :)
Typical way of  elimination of conflicting with you  body, may just cause elimination of the guy who is  feeding you  at the end of the process.
He is only as good as  his ability to sale oil and keep him on the top of   an empire.  Once he losses the grip he is  on the mercy of the crowd around.
And here in this place we  deal with Energy.
I'm very peace loving   friendly fellow
stivep
Some  material  related to the last  3 posts
Wesley
stivep
 I finally have got the  entire page
I did not translate it yet
Wesley
Void
Quote from: stivep on January 16, 2018, 06:52:51 PM
Wesley
Hi Wesley. What is that circuit configuration shown on that page supposed to do?
All the best...
John Smith
https://www.youtube.com/watch?v=XInN3jk1Hy0&t=2s
