0 Members and 415 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on February 08, 2019, 07:26:29 PM
   AG:
   Glad that you are amazed. I just follow the directions, it only took two years to get it to that point. Just using a simple Kacher.
   I'm still going to build the controllable Kacher circuit, like Geo, Geg, Itsu, etz...  I WILL get it to work as it should.
   I don't give up, ever, just need some motivation.  It works exactly as stated, but no one really takes the needed time to properly tune it to each location. The ground line is very important, use only the welding cable for best results, and use only WIMA caps. Follow the winding instructions to the T. Listen to the intensity of Ruslan's spark when he shorts the 0.47uf cap(s).
   Normal resonance is only part of it. The device needs to be disruptive, and resonate with the Aether, also, or it's no cigar.
   You can't fake a device showing a 4000w output by connecting an invisible super thin magnet wire to power the device.
It will go up in smoke.
   Good luck to all... don't give up, don't give up, don't give up...  That's what "they" want us to do, is to forget the whole thing.
   There are too many of these types of devices shown self-running and not every builder is a magician, so ignore the BS.   We will crack this nut... if we work together.
A  0.47uf cap is your tank coil slosh storage capacitor? but is it in tune and in tune with what data window years ago I worked on HD data recovery systems using phase lock loops, got it working too on a 16 bit z800
what makes this only different 'modules' build a module get it working and add it o the next part of the idea.
Read the last 20 pages and dump all the crap negative junk you might get somewhere then.
Preferably this Ruslan idea !
AlienGrey
Quote from: steadyfield on February 05, 2019, 10:56:31 AM
Hi, all
I did a preliminary test today. The setup is similar to the attached schematic obtained from this forum. The inductor coil is 21+20 turns in 2 layers, and the kacher runs at 1.83MHz with ground wire and antenna connected. The resonant caps of series LC are 2x0.47uF low ESR film caps (also tried 3x0.47uF). L_grenade = 150.27uH, L_inductor = 72.38uH.
Good things didn't happen. As I turned on the kacher with the push-pull already on, the bulbs doesn't give out more light. I tried different frequencies ranging from 10-20kHz, the result is the same. I also tried flipping the connections of the 3-turns winding on yoke, the grenade MAIN coil, or the half-wave rectification diode at the output. Even tried adding a diode between the negative rail of kacher and ground. Got the same results.
However, I noticed what is called the "Radio Moscow" effect mentioned in this huge thread. That is, with the kacher and the push-pull both turned on ,when one moves his hand around the grenade/antenna, the yoke gives out different pitch of sound.
still wondering what's wrong.
Jeg:
You mean the unipolar pulses waveform is actually the CURRENT flowing through the antenna?
Hi Steadyfield and Nick
Are you aware Color published a paper a few pages back on how the device works I would suggest
you find it and read it till you understand it and ignore any other BS others might give you.
Good luck
NickZ
   Well, looks who's back...   Geo: Thanks for sharing.
    https://youtu.be/u8TyUjhlDB0
justawatt
Hi geo good to see you.
I want one help from you I will share one video it's not clear.
I will post the circuit here.
Basically what he have done is the output coil is shorted and
Load is connected with shorted coil and ground.
Can you short the out put coil of Ruslan winding you have
And connect load with ground.
https://m.youtube.com/watch?v=lwRPRiOyyss
NickZ
  Geofusion:   Nice video, hope to see your rig all put together and working with the grenade and output feed back circuit again sometime.   Below was a video that I made some time ago, taking the output from the yoke 28 turn coil circuit, and rectifying it, and sending it to the simple Kacher circuit. Remember the old Mazilli driver?  It didn't work so bad, back then.
    Welcome back.
    NickZ   https://youtu.be/Yr25PT2iM9o
    This video below is about a star gate or portal. Let me know what you think about it.    I know that it's off topic, but it may be of interest, to some of you.    https://youtu.be/b2kZjzR-tJ4
