0 Members and 36 Guests are viewing this topic.
AlienGrey
Nick that circuit sets the 2SC2500's bias to mid-point and depending on its gain on how lossy it is
the other problem is it's always running to saturation Adrian's didn't work like that nor did Ruslan's
it needs to be hooked into the switching time of the yoke at the right time, not random.
You might think this is off topic But If you remember Color keeps slipping some girls picture
in his posts well you don't reckon her name is 'our Monica' to remind everyone about that fact
What fact you ask 'harmonics' what else.
Oh, you didn't build that heap of junk Shark was pedaling  ;D I made it and a PCB board too,
It doesn't work all the Mos Fets he says to use have far too much 'C' it's junk! but doing a circuit to solve that switching problem is a good idea but not that one.
My test rig run from a sine wave and a square wave same output and coil
40meter Katcher wound 1/2 length 10m
NickZ
Quote from: AlienGrey on March 10, 2019, 11:15:24 AM
   AG:  Not sure who you are posting to, but,  Geo has shown the Akula kacher circuit built up, and it seams to be working just fine.
   No one is "pedaling" anything.
   There is nothing "random" about the tuning of the simple Kacher circuit. It can be tuned to the proper frequency, and it's input is also controllable if using a DC to DC converter at the input, up to 50v, or so.  Ruslan, Stalker, and Adrian have shown self running, using this simple Kacher circuit.   Nor I have not burnt the 2SC5200 transistor, as yet.
AlienGrey
Nick and others, it won't work off 24volts or 12 you only need 3kv 3.5 max not 20kv if he has his working
I would like to get it to work but as it is it's junk show us how he has altered it to work because this one is far to slow and useless and show us some waveform on the scope Geo a new circuit diagram, would be nice
So what's my problem with it RESONANCE and my guess is it's to complicated the way it is
apecore
Jeg, NickZ,
Thanks to you all....and of course all other active and passive members.....  good to see this thread is still alive..
Yes.. i guess most of us do miss something... as they probably did not yet hang it on yhe wall.
As i said longtime before,..  i m only here for the experiment and second hoping to see if some "wierd" results are scalable and explanable.
Of course not in manufacturing any kind of Boost buck converter with a grenade coil.
My personal approach is very down to earth as it should be simple.
Disruptive pulsing with HV field, proabably disrupting the magnetic field created by the inductor.
During this disruptive stage there should flow energy inside the grenade/ inductor coilpair.
On the otherhand some schematics show the 28T yoke winding having a different function then powering the kacher circuit..
Justawatt and Magpwr posted it..     « Reply #20544 on: February 16, 2019, 06:49:54 PM »..  "We drink now and do nothing more schematic"
This 28T does generate squarewave's ( also disruptive)...... and in some schematics connected in series with a cap to the grenade...
By changing the series 28T cap..  ( as mentioned by AG .. switch capacitor).......i can create "Radio moscow"noise out of the yoke..  with out the kacher running.
With no doubt...  28T and inductor loop magnetic fields both affect the grenade.......  some moment here the kacher burst comes in...
This kacher "burst"  as T1000 several times pointed out is very critical in tuning to this "Charging" performance stage.
In my opinion.... we still aint able to make a "unipolair"puls @ antenna with the kacher setup ..  it still has a sinewave......
Did someone accomplished this "unipolair puls"at antenna?......
Greetings
AlienGrey
Mr Apcore No No No if your getting a square wave out it will not work it's a swing, not a hammer and what frequency are you getting the square wave and whats your wire length 40m or 37.5m ?
If you experiment I will tell you what's wrong with that bit!
