Void
Thanks for sharing your test results Conico. Nice build!
AlienGrey
Quote from: conico on March 11, 2019, 04:59:54 PM
I put the function generator on ''antenna'' and the scop show me a maximum amplitude of grenade coil at 840 to 860 Khz and an other point  was at 3.4Mhz. I didn't succeed with Katcher at 3.4Mhz.
Anyway I don't like Ruslan devices you can not start them with 9V battery. The devices must be simple, Kapanadze said.
I try to tune the inductor and series cap at 60th of harmonic of 860 khz, first the device work at 14,xx Khz but is the same result as now
Yes i had that with one the kaccha I played with 4.something meg I just treated it as in Akula video and used some 15kv caps to bring it down across the HV coil itself about 30 pf got it down to 1.5 MHz for 40 meters just about right now I get a nice large sine wave at its proper resonant frequency I haven't seen anyone use 1/60th is all I have seen is 1.5mhz = 15khz on grenade inductor but 30 would have a better xl impedance, if you remove or add turns it's no longer all in resonance I wouldn't go down that avenue my self it messes up the Lambda and you end up with bin fodder,
NickZ
   conico:   You can raise your Kacher frequency just by removing some turns. You can also put the secondary coil on your SG and test to see where it's best amplitude is found at. You can also control the frequency using ferrite inside the Kacher core.
   As you may have seen, unless the Kacher is perfectly matched to the induction circuits, you won't get the best output, nor OU, and much less self running. That is probably where we have all failed to obtain self running. Of course, that is just my opinion.
   My frequency does not change when the Kacher is also turned on. But, that depends on the way your system is wired up.
   Using Geo's older wiring method, hardly any light or output is seen on my bulbs, until the Kacher is also on. Once I turned on the Kacher, it can light 3 or more 200w incandescent bulbs, partially. And the Radio Moscow signal can also be heard. That sound is an indication that there is some imposition of the Kacher to the induction circuits. As well as the bulbs getting brighter than with just the yoke/grenade circuits.
AlienGrey
NickZ my dear friend I know what your saying and why your saying it, but experimenting and getting results is and then putting the various experimental modules away after is one thing for experiments but actually being GOADED ON BY SOME SORT OF STIMULUS into running such a device for gain might well be illegal so your right I don't have a running device nor am I interested in an autonomous or auto-starting device  but it doesn't mean I'm an idiot either !
I hope that explains my position.
ag
NickZ
   Well AG it would help if you and guys like color don't continually pretend that you know what you're doing concerning these devices, when you don't. Misinformation given to people hungry for the truth is not helping them, nor you.   I know that you are interested in this topic, or otherwise you would not be here. So, again, don't pretend that you don't want to know how these devices work.  You like Wesley and color are more of a distraction, than anything else. Sorry, but that is what I see here. It would help if you just qualify your comments with, I believe, or I think, or it seams to me, etz...
