0 Members and 717 Guests are viewing this topic.
apecore
Quote from: AlienGrey on May 09, 2019, 06:53:23 PM
what do you call a square wave one MOSFET overheating the other cold  ;D ;D
50/50 is a square wave. see scope shot.  2674
https://www.electronicspoint.com/forums/threads/pll-un-equal-square-wave.59160/
AG,
I don t get you anymore...
First you say a CD4046 doesn't give a squarewave..
Now you talking about 50/50 one mosfet???
I can tell you i have no problem with running my DRSSTC with a 74HC4046 in PLL mode...  even with interupterpulsing for only 2 or three cycles @ 2.0mHz
It works all fine and gets in LOCK in a blink of a eye
Greetings
NickZ
   I think that AG is talking in a new code. Payamas, money, cut the cake, and get more back than when you started.
   Everything is in code now. TopRuslan secret code. And Ruslan won't say... So, who's going to crack the code? AG?
AlienGrey
Well here is a Vero card with a CD4046 test rig(no different from a 74HC low voltage version) in the output waveform now look at the waveform you call that a stable square wave ?????????????
So what might happen if you start to process this signal in the 'real world' ?
apecore
AG,
Yes you using the CD version....
See my scope_shot @ 5 Mhz +.
Greetings
AlienGrey
Tried it originally with 74HC4046 so did Itsu it was exactly the same made a PCB for it too.
The circuit also has other problems that have not been resolved and errors regarding feedback to the LM393
to the phase, lock is only a phase shift controller that doesn't work as is! to correct it would require another 4046
It's to do with the chip works it pulls the wave one way or the other, it needs a latch to stabilise the wave on a rising edge.
Where you show it in the middle, nice one till it does real work.
