0 Members and 68 Guests are viewing this topic.
AlienGrey
Quote from: NickZ on June 24, 2019, 02:32:20 PM
   Geo:   Where does the idea come from that a plastic torroid is what is needed on the ground line? Did T-1000 test this idea himself, or is there some device showing what the signals should look like using a plastic core?
   Both Ruslan and Stalker have used ferrite torroids, on the 3t coil circuit. Not on the ground line.
   Where am I going to find a plastic torroid former???
I have a little baby blue one should i try it at and see what it behaves like frequency wise ?
apecore
maybe wood will do also,... just try,,,  Geo is trolling you,
his torroid is also ferrite
on the other hand the schematic shows that the GATE of the FET is connected to GROUND....  Apparently the connection to ground on the secondary base (karcher) is NOT @ ground potential.
It must be using a long ground wire (ie; 18meters?) and the connection point >> FET gate is above ground potential obviously.
This looks like a half-ass attempt to construct a feedback loop w/ mininum amount of parts............LOL (using only a wire).
The Zeners are there to clamp any excess voltage that comes across from the karcher secondary base connection.
lost_bro
Quote from: apecore on June 24, 2019, 02:57:02 PM
Good day All:
To add to the above..........
Groundlines are NOT simple creatures.
Anyone who has ever operated a S.W. radio (ham operator) knows what I am talking about. Once you read a bit about RF grounding for radio applications, it becomes apparent the avoiding **R.F. in the Shack** is just as much an art as a science.
Various methods have been used............
"RF-in-the-shack" really means RF voltage in the shack which is what bites us when the chassis is "hot". We can have high RF current in the shack and not even realize it. The purpose of a 1/4WL wire connected to the transmitter chassis is to move the voltage maximum point from the transmitter chassis out to the end of the 1/4WL of wire. There is just as much RF energy in the shack as before but we have forced it into the magnetic field (current) on the transmitter chassis rather than existing in the electric field (voltage). But that 1/4WL of wire will radiate just like 1/4WL of a 1/2WL dipole antenna (and may be physically too close to the operator). The energy in the forward and reflected waves on that 1/4WL wire does NOT cancel. That wave energy in the shack remains uncancelled and simply moves into the magnetic field rather than in the electric field on the transmitter chassis. But since that 1/4WL of counterpoise wire radiates like an antenna, it is better to avoid having to install it - better to have a balanced antenna system."
https://ham.stackexchange.com/questions/3523/grounding-a-second-story-shack-with-an-outdoor-antenna
An "artificial ground" box (MFJ-931) is somewhat like an antenna tuner for the ground wire (it is composed of a series L/C -groundline&capactor and tuned to the operating frequency of device in use). This effectively *tunes out* the AC reactance of the ground line.
Attached is a schematic and info. for this type of apparatus.
Although, until the M.O. of the Ruslan device is understood, it is anybody's guess as to **where** the magnetic and electric components really need to appear in the system.
take care, peace
lost_bro
AlienGrey
collecting energy from the ground
NickZ
  So, guys... here's a couple of pics of my plastic air core coil, to test the ground line response.
   It also resonates at 3.2MHz. As my other coil had done. I'll show more about that, soon.
