0 Members and 42 Guests are viewing this topic.
Raycathode
Re OUR forum
Chet Hi, further to OUR problem. Itsu was asking me if I had tried a different search engine like Firefox or Google Chrome the answer is it's the same  ;D  I also tried Internet Explorer and that comes back with an error. It says OUR is not responding on there end.
I did try to change my IP address but it looks to be fixed by my provider some aren't and changes each time you log in but mine isn't like that so that's it.
If you do a cut and past with word rather than a screen print it copies small segments and it might have not liked it.
I sounds like the OUR firewall has kicked me out!  ;D 8) :'(
ramset
Do you have a public library or friendly neighbor or Grand kid with a cell phone ? [try logging on]
I can ask Peter if he has ever heard of this problem ?... did not think there was or is a mechanism to limit a public viewer from copy pasteing ?might be some kind of Botware inhibitor ??
maybe your aftershave ?[smell like a bot ? :o
Thanks Grandma
Raycathode
Quote from: ramset on December 29, 2019, 11:33:41 AM
I can ask Peter if he has ever heard of this problem ?... did not think there was or is a mechanism to limit a public viewer from copy pasting ? might be some kind of Botware inhibitor ??
maybe your aftershave?[smell like a bot? :o
not that live locally no but can try the library in the village but it's not open all the time.
the two kids have machines but I bet they have the same IP address of the one provider.
Raycathode
Here is a Charge and compounded energy discharge pump circuit I have been working on over the holiday
It works with a capacitor being charged with a constant current charging a timing capacitor a bit like a popular
timer circuit  does until it reaches a threshold voltage and then fires an NPN and PNP set up as a bit like an SCR
that has a threshold bias level and shorts out the capacitor almost instantaneously compared to a TV flyback
equivalent circuit but not quite as fast as when an over voltage breakdown would.
There are a few problems with this type of set up mainly the SCR device feed is high impedance and it doesn't
bottom out to the negative rail but comes close to a transistor junction both of which can be sorted out with an
opamp and two power drivers using a slave charging cap dumped into a tesla secondary coil the slave cap is also
current is driven and is only offered as an Educational device for others to build and experiment with.
Here is a scope shot of the waveform produced by the device st up as a low-frequency device at only a few hundred
cycles repetitions.
The supply voltage is from 12volts up to 30v and is only limited by the output driver opamp a TL071 in this case as it
directly drives the output devices.
Ntambi
Happy New year members....
I have been watching these forums and the free energy infor for quite sometime and it has taken me a great deal of time..
The biggest problem I'm seeing is people are just copy and pasting that's why we have a few that have made it....
Leaving that I want to share some of my research to give most of you the right direction... I will start by asking you to look at the work of the following people... Weasley arunas and Aida's, SR 193, Tiger2007, the video translated by stivep1 of tungu "Akula" with an output of 750watts, the video of tariel kapanadze of 2004 and the patent of Michel Meyer... All of these people have something in common and that is low frequency generator of 50hz acting as a carrier frequency and a high frequency generator...
The others a part from tariel kapanadze and Akula said they used the 50hz as the modulation frequency but if you look at tariel and akulas videos you will ask your self why they included invertors in there devices...
I have alot to say but I hate typing but here is the theory of what's going on, we are creating a super magnet from the ferromagnetic material with ability to control it using a very weak force by using nuclear magnetic resonance...
What happens is when an atom is placed in a magnetic field it tends to either orient it self against or along the magnetic field and this is done by the low 50hz frequency, then when the small magnets have been arranged we resonantly turn them by applying a magnetic field which matches there precession frequency there by creating a strong resultant feild with less in put... The biggest problem why most people have not been able to replicate stivep1 and tigers work is they forget backend, the small papers that where put between the ferrite yoke in Lithuania were reducing back end... But the paper thickness depends on the frequency used and material size, what we can do is apply the same method but with a different approach by using Thane heins no back end transformer with this concept, by doing so we will be able to create the super magnet and take out power without disturbing the source....
If you have proper instrumentation, try this, I know you will have free energy I'm sure because I've tried this and I got the free energy
