0 Members and 305 Guests are viewing this topic.
conico
NickZ,
I'm not going to make a movie with my system, it's just like yours or Geo's that you posted earlier.
I turn on the katcher and 2-3 light bulbs partially light up. No OU. It is 100w from PSU and just 80w on the load.
I understand what is happening. The push-pull frequency is not correct.
watch the movie from minute 1 and 16.
https://www.youtube.com/watch?v=_GO2ADSPbK0&feature=youtu.be
There are two waves out of phase 90 degrees because grenades coil is half CW and half CCW. When the signal increases, that twisted wave with maximum amplitude appears.
The stationary wave of the grenade coil is at maximum amplitude.
This is how the push-pull frequency can be determined.
If you know the push-pull frequency you can easily find out the frequency of the inductor and the Katcher as well.
push a the swing at the right time to have the maximum amplitude, otherwise it will have small amplitude or even stop it.
I will disconnect the inductor and what is on the load and I will use push-pull to find that twisted wave on grenade coil.
NickZ
   You will also find that figuring out the sync frequencies will not give the needed results.  MATH WILL NOT WORK IN THIS CASE.
  You'll see what I mean when you figure that part out.   I 'll talk to you more about that once you are done with your test.
   NickZ
NickZ
   conico:   please check itsu's channel where you will find over 17 videos about the Ruslan type of replications.  youtube:
  itsusable channel.
AlienGrey
Hang on wern't you only a week or two ago telling me no one on OU Re serch had nothing working ? so whats the point in him copying something that doesn't work, where is the logic in that? :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\
EMJunkie
Quote from: NickZ on June 27, 2020, 04:14:01 PM
  itsusable channel.
NickZ and all reading, with respect to Itsu, I truly don't believe his work should be used as an example!
Without Understanding, no direction can be gained, and if no direction is achieved, the Wheels on the Car can be very Square before one is able to realise Round Wheels might be better!
Reading Conico's post:
Quote from: conico on June 26, 2020, 03:53:19 PM
NickZ,
Conico's approach and thinking is on the right track as far as I am concerned! He has a clear and sensible approach, one that will move him forward! Well done Conico!
Dont forget about the Amplitude Ruslan told us about:
Quote from: TopRuslan
I repeat, you need to make the voltage on this harmonic not 10-20 volts, but higher by an order of magnitude. Approximately up to 50-60 volts and get the same dancing effect at the output. Further ! Do not forget that Tesla does not need strong power. Do not let sparks run and wet so that it breaks through. This is not necessary !!! It's better to make a controlled Tesla. Continue: The output voltage will be 195-200 volts. This voltage will not be higher. Why? Later we will return to this.
Ref: Here
AG makes a wise comment also:
Quote from: AlienGrey on June 27, 2020, 09:22:53 PM
I urge you, please, PLEASE, don't let others work influence yours blindly! This is a really dangerous approach to Research! You are bound by others Dogma! Steve Jobs said it best:
Best wishes, stay safe and well in these dire times,
   Chris Sykes
