0 Members and 261 Guests are viewing this topic.
AlienGrey
down load original on screen click on it save it to my pictures then load into paint change it to a *.png file then save it then use over unity          dot com messager to shove it on screen via the browser button
simple
AlienGrey
Quote from: soliman on October 05, 2020, 06:30:22 PM
hi,
in the blue box are the modifications I made to this circuit
which gave me interaction with the earth. in case anyone wants to evaluate it.
if you use a value of 10uH to 100uH or something like that. keep in mind that
it will burn a lot of mosfet. it is better to use from 10mH onwards.
a variable power supplay. Careful up to one volt could burn your mosfet. If you do it well.
it will have a high current in the ground wire.
NickZ, use 100mH(choke coil) instead of 100uH and You will see how different it is.
Be careful, mosfets can burn.
ah remember to watch the Geofusion videos again, he insists a lot
over and over on the earth wire.
according to several comments that I have seen, the earth can be of 5, 15,
18.5, 30, 37.5, 46, meters.have you evaluate it?
all lands are not equal.
Cheers!
you can current limit the MOSFET dead easy with an  SCR and a couple of resisters
I will post it later on  but it wont protect it against over voltage you need a TVI diode for that as well
conico
Hi, Soliman
Thanks for your choke information but this 10mH choke is for those who have a controllable catcher. 10mH choke is not good for those who have a normal katcher like me or NikZ. Normal Katcher is made with 2SC5200 and no mos-fet and is not a controllable one. A Katcher like Soliman's is  very powerfull it gives 5 to 7Kv on anttena, normal Katcher give 2-4Kv on anttena.
I only have 160V on load with normal katcher and not 240V like Soliman.
You see Kapanadze's 5Kw system has a small spark-gap and the 100Kw system has a huge spark-gap.
I think that my system as well as the system of NickZ and others are good, only we need is 5-7Kv on the antenna.
I forgot Soliman, if the length of the Tesla secondary is 20m, you must also have the ground wire 20m too.
NickZ
   On 24v, my Kacher can have a 1cm streamer, (10.000v). But, I find that that much HV can damage things, so I use only about a 4 or 6mm streamer, instead.
   The choke that I use on the front of my Kacher's input source was one that I wound myself. So, I'm not sure now just what specs it may have. But, the idea is to protect the mosfet, from overcurrent, by the use of this choke.   I already have interaction with the earth ground line (37m long going into my water well in my back yard), when the rest of the device is in tune and in sync. The 37.5 m long thick ground line, is the same size as my grenade. But, still no OU.  So,  I don't get too excited, just because the ground line helps to light up the bulbs up a bit higher. Until 100w input = 1000w output.
   The size of the kacher secondary is not 20m. It is tuned on my device to resonate at 1.5MHz, yet it runs best at around 1MHz.
   Now we've got Jeg, apecore, and some of the other old timers back, again.  Nice.
   I still miss itsu not being here, even though I always follow his work, elsewhere
   It's unfortunate the problems that trolls and other problematic people have caused to some of our original hero members here.
    NickZ
AlienGrey
Quote from: NickZ on October 06, 2020, 08:33:34 AM
37.5 m thick ground line, same as my grenade. But, still no OU.  So,  I don't get too excited, just because the ground line helps to light up the bulbs up a bit higher. Until 100w input = 1000w output.      Now we got Jeg, apecore, and some of the other old timers back, again.
   I still miss itsu not being here, even though I always follow his work, elsewhere.
   It's unfortunate the problems that trolls problematic people have caused to some of our original hero members here.
   NickZ
Nick i don't want to up set the apple cart here, but some times we can keep throwing components into a DESTRUCTIVE
circuit idea, Mr DELONARTO said on Wesley's thread, was a spark (involving) two close wingdings (a short article) just transfers energy across one circuit to another Hadley over unity, so one must come to the conclusion that some device or process is missing that would excel-orate  the process.  You need to find a way around that obstacle.
Gravity is a force of subatomic particles, also exert forces on one another.
PS, what has 37.5 M got to do with this project ? that's not what he says in his video's I'm surprised no one else has mentioned this before. It's so easy to build bin fodder only for it to end up at the tip, other than it being a good way for it to end up at the land fill.
Back room guys
