0 Members and 40 Guests are viewing this topic.
AlienGrey
Yes Jed some Russian speaking guy sent me this !
Translated it says
Secrets of the TL494 or half twisted guys in the Shark flashlight.
NickZ
Quote from: Jeg on October 08, 2020, 02:51:53 AM
Hi Nick
Thanks for sharing your video.
What is the frequency of the signal which is seen at your oscilloscope? Is it the high frequency of your katcher module? Or is it the low frequency of your system?
ps (later added). Is your Kacher modulated? Without modulation just forget any progress. Is it at least in sync with your push pull? A continues Katcher operation with out timed brakes will lead you nowhere. Any advice from folks here will not help at all in such a case.
   Hello Jeg:   There have been several replication now showing no real OU with any of the controlable, or nor controlable Kacher circuits, along with the rest of the yoke/grenade circuits. Even though now Adrian which showed the simple kacher circuit self runner, is now dead.
   So, when Geo, yourself or any others guys can show how well the controlable Kacher works to self run, we can all replicate and get ahead in this project. But, until then, it just looks like we are all just still chasing wild turkeys. And Geo, is still lost in space, again.
Jeg
Quote from: AlienGrey on October 08, 2020, 08:58:07 AM
Translated it says
Thanks AG. I had posted again this waveform at least twice in here. I had also asked this guy how its made. Here is the dialog: https://www.youtube.com/watch?v=0bBTqA6opUY&list=LL&index=39
"Thank you  for sharing. At 10:17 there this high frequency waveform. On which point inside the circuit we look for this? Jeg"
"Высокочастотный сигнал генерит ТЛ494. Паузы между ними делают усилители ошибки по параметру степени насыщения феррита. По сути тут два генератора первый на внутреннем генераторе 494, а второй параметрический зависящей от силы тока протекающего через L1 снимаемый на шунте R1."
Google trans: "The high-frequency signal is generated by TL494. The pauses between them make the amplifiers errors in the parameter of the degree of ferrite saturation. In fact, there are two generators, the first on the internal generator 494, and the second parametric depending on the current flowing through L1, removed on the shunt R1"
AlienGrey
Jeg I'm not into the Device as such I wasted time enough on that as a green novice retro bate a good few years ago now.
I got the modulation wave form as that's what is needed to pass energy from the katcher oscillator to the grenade
but it still wont work as it is not a more in than out device (Electron accelerator) so no point in making any further this way.
Dr Steven Grier has said many times solve that problem and you solve the anti gravity problem till then fun and games or do other thing that's been left, perhaps play with old relay coils to see what back emf is like.
NickZ
Hi Nick
   Jeg:  That was the HF/HV kacher signal, as read by the HV scope probe, with no negative ground probes attached, at round 900KHz, or so. The point being was to tune the HV/HF signal and frequency to interact with the induction circuits.  As you can see in the video, there is some interaction, but not enough, at that time. Yet it can partially light 3 200w bulbs.
However, I see no improvements over that output, by the other shown controlable kacher circuits, as yet. And so I've been waiting for you or apecore or Geo, to show me how well your controlable circuit works to self run.  And, I'm still waiting...
   NickZ
