0 Members and 360 Guests are viewing this topic.
AlienGrey
AlienGrey
AlienGrey
WARNING: Tesla accidentally discovered that electric spark
discharges in air, ignite and burn atmospheric oxygen and nitrogen, producing 12,000,000 volt waves. The
oxygen and nitrogen, both below atomic number 19 are thereby transmuted into alpha and beta charges
(stripped helium nuclei with +2 charge each, and electrons with -1 charges each) by the powerful radiation
produced, having a voltage potential of 12 Mev. This is almost three times the Mev level of gamma radiation
emitted by radium, it may well be the reason why Tesla did not publicize the device shown above, and
should you decide to experiment with it, please be aware of the potential hazard of this radiation.
color
Quote from: AlienGrey on February 11, 2022, 05:34:38 AM
https://ncache.ilbe.com/files/attach/new/20220212/377678/3989599606/11394797210/283f52e903beb8eb42c399a86544cab2_11394797253.mp4
;D ;D 8) 8)
https://ncache.ilbe.com/files/attach/new/20220212/377678/10634749858/11394797457/c5d5f7213c8ce668d8cc42aec02600c9_11394797491.mp4
magpwr
Quote from: AlienGrey on December 22, 2021, 09:31:54 AM
PCB layout with corections, board works but never made wholer device thats your game!
hi AlienGrey,
The circuit provided by Akula needs tweaking.R13 1.2k and R12-460 was replaced by a 1watt 5k trimmer.The base of transistor connected to the trimmer center."Please test any unknown circuit on breadboard first before wasting time to create final PCB"
It's comical to know the KT805A is rated 60v but Akula did produce deception related to the incorrect voltage from the yoke to power the tesla.Rising above certain voltage would kill KT805A transistor same for 2SC5200.
If you got a 220v low power bulb 5w...10watt connect that to your variable power supply it needs to be below 18volts before you stop seeing any glow in the filament.
Now take a look at Akula presentation photo did low wattage bulb filament glow? ;D
This is the simplified version of Akula circuit.Take top half circuit from R4 link it to both input ofTC4428(Replacement for 4 transistors in Akula circuit) which is powered by 12volts.As usual do test it on breadboard first.You will know the value of RV1 and RV2 eventually.IR2184 was replaced by IRS21091(8-soic) which the DT time 500ns can be further increased by trimmer or resistor.
Nothing much to add. 8) :D :D :D
