0 Members and 447 Guests are viewing this topic.
Hoppy
Quote from: 00 on September 12, 2013, 04:06:36 PM
chubinidze flyback driver circuit
00
How did you test this circuit for OU coiling, or did someone just tell you that it is OU?
guruji
Hi 00 that flyback driver is nearly like mine but I used stronger transistors.
I did no resistors in parallel and led.
Two 220ohm resistors
I have to check my winding though.
Thanks
magpwr
hi everyone,
I have just uploaded into youtube my high efficient "1 watt HV flyback transformer" which can be powered by 1.5volt to 6 volts since i'm using small heat sink.My objective is to generate hv using low power input.
http://youtu.be/BoUivNtYFIA
For demo i merely connected 2N2 50kv capacitor at HV output to light the 220volt 5 watt bulb.
For the npn transistor i have tried more than 10 types eg:2n3055,tipxx and Japanese transistors.
Finally i found that using H1061 npn transistor gave the best spark around 1cm+.The 2n2055 did not perform well about 1/2 as efficient as the H1061 base on spark width.
Please use capacitor 470uf to 1000uf to increase efficiency a little as shown in video.
00
Quote from: Hoppy on September 13, 2013, 04:36:34 AM
hi hoppy!
electricity comes from a magnet. so we make magnet. we make dc magnet not ac magnet. if we make ac magnet then overunity not possible. as in ac one half is counter of the other so magnet is produced half half not unity magnet.
00
Hoppy
Quote from: 00 on September 13, 2013, 10:13:03 AM
hi hoppy!
00
OK, so I'll take it that you didn't test it for OU.
If you wind opposing coils like you show in your flyback schematic, then you will just end up with a hot ferrite and a lot less output than if you had connected the two coils conventionally with a centre tap for the Royer oscillator, which is basically what you show.
