0 Members and 415 Guests are viewing this topic.
TheCell
Wind the coil from bottom to top then your matching 00's cw/ccw definition.
(I can't agree with the eyes pov)
Have you mentioned how many turns the bifilar coil has/ if important?
(Yes it has no inductance, regarding the current flow)
I tried setup with 3C90 ferrite core and a coil wound on top these and aluminum foil
between the bifilar and the inner coil with no positive result.
My inner coil did not have an air-gap, so I might blame it on this.
There is not much space in my setup for a sliced aluminum core.
So I ask if a foil is sufficient?
Hoppy
guruji
I don't think it makes difference if all coils are CW or CCW?
Hoppy
Quote from: guruji on September 19, 2013, 02:35:23 PM
Possibly not but there is an inconsistency in 00's diagrams. He shows a true anti-phase coil arrangement between legs 1 & 2 in his flyback schematic but the inner windings legs 1 & 2 over the ferrite core are shown in-phase as they are a drawn and labelled as a continuous CCW wind with just a 1" gap in the middle. As I understand from 00's text, both the flyback and ferrite coil legs are supposed to be wound anti-phase.
magpwr
hi everyone,
I have made an interesting discovery last night on my 3layers with 20 turns on each layer(CW) and 3layers with 20 turns on each layer(CCW)
2.5mm electrical wire was used for the windings.
After connecting both CW & CCW winding in the middle .Base on multimeter Ohm reading it's 0.9Ohm for each winding for both CW & CCW.
This is a interesting part.
Since we all know connecting 2 coils in "series" each with 0.9ohm should give us 0.9Ohm+0.9Ohm =1.8Ohm.
But for CW and CCW winding it's the reverse i'm getting 0.5Ohm since i know my multimeter can't give reading 0.45Ohm.It was simply rounded off to 0.5Ohm instead.
The resistance of the  2 windings in series consisting of CW & CCW became half instead of doubling.
It's like cancelling each other out.I wonder if "negative resistance" could be applied here.
"The only way to prove me wrong is to experiment.I know there is no error on my part"
