0 Members and 2013 Guests are viewing this topic.
Hoppy
Quote from: NickZ on October 17, 2013, 01:53:25 AM
  I don't see what the confusion is about ,with GeoFusion's same direction, center tap primary coil advice.  I got it.  It's very simple. Just wind the primary coil one way, tap it in the center.
  But, what has not been tested is if it actually makes a real difference to go in opposite directions, and just what the difference is. More or less power output, or is it just the same thing, and makes no difference at all.  It made no difference in my case, at least that I could see on my Akula yoke replication.  But, I'll try it again, only take a few minutes to reverse one side of the coil, and take reading one way, or the other.
Then we'll know.
  There are many variations of the Royer induction heater circuit. But, which is the best one for our purposes?  The one that works, maybe, huh?  Cuz, up to just now,  none have worked to self run the circuit.  Unless you got magic shoes on,  like Geo.
Nick,
It sounds like you are beginning to realise that there is nothing magic about my, yours, Igor's or GeoFusion's and other similar experimental coil coil setups we see plastered over the pages of this forum. They are simply straight induction transformers that all work under unity to light bulbs at different efficiencies depending upon the design variables. The truth of this can be seen when proper methods are used to measure these experimental setups. If there is any magic involved with the Kapanadze / Akula devices, then its down to another element which is unknown to us at this point in time. We are given some tantalising clues as to the probable nature of TK's devices, that they are difficult to tune, that a large capacitor bank is employed to store energy sucked from the ground by coils that are creating a high potential above ground and above all that the devices are so simple, you'll laugh!  :) However, none of this makes sense to me when there is no source of real power, other than a small 9V battery to start the device and power the induction pump sufficiently to begin drawing up tens of Amps from the ground into a capacitor bank, which requires the belief that are tens of Amps available to be sucked-up from the ground, through a wire hand wrapped to a water tap feed pipe acting as an earth rod!  ??? Surely, if it were that simple, the power companies would be out of business by now.
verpies
Quote from: Grumage on October 16, 2013, 03:21:38 PM
I have attached a pencil sketch of the two methods of winding the primary. Please would you indicate which one you have used? I have sat at the kitchen table and rotated my fingers and you will see if you try it yourself the fact that starting out from the centre going each way (behind yoke and coming forward)  they both still have a CW/CCW relationship!! Looking from each end!!
IMO the two core halves need to clap against each other in order to cause strong acoustic vibrations in the core.
This means that all experimenters using mechanically immobilized cores or undivided cores are destined to fail, unless they are lucky enough to be saved by some strongly magnetostrictive core material.
I already mentioned  here why mechanical vibrations are important.
The best way to assure this is to alternatingly create aiding and opposing flux in the core, because aiding flux attracts the halves and opposing flux repels the halves.  At what frequency this needs to occur is another issue....
See the attached diagram below.  You can also compare it with the series-connected windings here.
NickZ
  Hoppy and All:
  What I do see is the GeoFusion's device is not like Akulas, at all, yet, may be working in a similar way, somehow, if that's possible. The mistery can be accomplished by accident, still the key is not to just light bulbs, while draining the battery, but to do it without a battery or without discharging it. This we still have not proven, at least to my satisfaction.
  Many people have posted devices that they say produce OU, but in the end, they don't.
  So, Hoppy, I'm not being pessimistic about this, or looking for more x-wires, but I certainly am as leery as you, until I see it with my own eyes, and make it run with my own hands.   "Emperical evidence", Verpies said, (I can't even spell it).
Or buy it from someone, like our buddy GeoFussion. As he's got the right shoes, and such.  If I had the money. Ha!
  I also agree with a.king's last comment (...), could be the best one made yet.
a.king21
Yes, agreed about proof. So what next?
Do nothing?
Wait for someone to hand it on a plate?
Disbelieve Geo?
Go for a shower?
Mock people trying to help?
What do we do next?
So I think I'll confine my comments to ....
