0 Members and 303 Guests are viewing this topic.
magpwr
hi everyone,
I have cracked the Geofusion roundcore 1KW today and discovered it's just ahigh efficient voltage tripler device.
In layman terms if i were to put 12volts battery with 1KW halogen bulb load the voltage across bulb is around 34volts A/C.
If anyone recalled Geofusion did mention if he were to use 36volts for supply input the output would match the brightness of grid power supply.
36volts x 3 =108volts  (His 1KW Halogen bulb is meant to be run from 110volts supply).
Conclusion-Case Cracked.Well done Geofusion for creating a high efficient voltage tripler device using yoke core.
The mazzilli oscillator circuit with suitable capacitor would run at resonance frequency of the Yoke core.My yoke is running at 4.45khz.
To confirm i also used Pulse Width Modulator Control Circuit using one I/C:SG3525 to easily emulate the frequency to 2 mosfets or one which gives the highest output.Choke is not needed at positive supply.
Datasheet-http://www.onsemi.com/pub_link/Collateral/SG3525A-D.PDF
One of the example -http://tahmidmc.blogspot.sg/2013/01/using-sg3525-pwm-controller-explanation.html
I have attached my version of Pwm modulator with 2 x 1k resistors soldered onto board for output to mosfets.
The 2 white wires are the output meant to be connected to mosfets.
Mosfet gates needs to be connected to GND via 1MOhms resistor to protect mosfets.
The capacitor value used for PWM circuit is 0.015uf and both potentiometer value 10Kohms.
Frequency output base on capacitor value used 3.9khz ...22khz.
Pulse width from 6% to 50% to control output brightness.
************Merry Christmas ****************
Hoppy
Quote from: magpwr on December 24, 2013, 02:40:49 AM
hi everyone,
Yes, well done to GeoFusion for building an inverter.
Merry Christmas & Happy New Year to all
NickZ
  quote:
  "Conclusion-Case Cracked.Well done Geofusion for creating a high efficient voltage tripler device using yoke core."
                                   end quote
  Any oscillator can raise the voltage by three or more times. However, that does not allow it to self-run.  You're not getting the point... He has "managed to have it self -run"
  No one has built the RMG circuit, as Geo is showing. The circuit that works without burning out from overheating. What, too clear a diagram???
  Most ALL oscillators are inverters, until the input source is removed,  and the device  keeps running, on its own power. That is the point...
  No wonder that Geo has not been posting any more.   "nothing special"...
  There's nothing special about lighting a 40 what bulb. That is true. But, you haven't lit 300 watts of incandescent bulbs from your Mazilli circuit, or 3000 watts. Now have you?
Nor tried to connected it back to the input.   Maybe if, and when you do, you may see "something special".  Or, not...
