0 Members and 412 Guests are viewing this topic.
NickZ
   Guys:
   Please lighten up!!!
   Let him do as he likes, when he wants to show, or not show us, on his own times and terms. He would not have come back to post here just to pull your leg.
Be patient... he is being careful, as you would be too, IF you really had something like that.
  YOU have enough to go on already.
  Not one person in the whole world has made an accurate replication of the Tariel Kapandze, or of the Akula device. Not even Ruslan, as his only works at a much lower output, so far.
  Thank you all,
                        NickZ
Hoppy
Quote from: NickZ on July 09, 2014, 11:26:40 AM
                        NickZ
Something like what Nick? All we are trying to establish to start with, is what does he actually have. I've asked him if he has a self runner but as yet he has not confirmed it is.
magpwr
Quote from: zcsaba77 on July 09, 2014, 03:07:44 AM
Hi Magpwr
Exactly how look that primary coil test, etc.:function/nanopulse generator connected to coil trough mosfets, and whatever type metal rod puted to inside coil? like this? and what must see on metal rod? warm/hot? what will show us when will by best performance on primary coil?
When I previously post for NicKZ my opinion for changing output side coil, of course I mean when he want change output side he must reconstrued primary side too.
regards zcsaba77
hi zcsaba77,
It's simple aim for the metal to get hot/warm inside coil as a rough guide.
Parallel L/C resonance plays a very important role which should closely match yoke core output frequency.
At this point i need to be honest for Nick's experiment-
For Nickz's experiment to be successful in order to get a "thick coil" with suitable high voltage capacitor\capacitors  connected in parallel\induction heater capacitor and this would function as a induction heating coil if metal is placed in it.
Gentle reminder we are not creating a induction coil for heating purpose.Placing metal in it would merely let us know if there is sufficient power in the coil which then act as primary coil for the "multi layered coil/secondary coil"
To save time-He would need an "oscilloscope" to obtain the "frequency" output from yoke core.
After which he would need to wind a "thick primary coil" only without secondary layered coil in order to simplify\verify output power from pri coil.
L/C meter is needed to derive the uH reading of the "thick coil"
Then use online L/C calculator eg: http://www.mackrackit.com/djm/Web/LCR/LCR.html
Then apply the uH reading(This is static value.Unless you rewind the coil)
Then apply any capacitor value in nf(Apply few times by increasing or decreasing cap value) which will closely matched the yoke frequency.
Once the capacitor value is known.This would be capacitor/capacitor in parallel to match the actual capacitor value to use.L/C meter is needed to verify capacitance value never trust value written on cap.
Another method is the trial and error method which Nickz is currently applying for the right capacitors to use in parallel configuration  in order to obtain maximum output.
But if yoke output frequency is unknown this gonna take a long time to find out.
NickZ
  Hoppy and All:
   He has already mentioned what he has. I believe him. And can wait for the time when he is willing and able to show it. And if not, there are already schematics, videos, and such, of already working systems. Yet, most will not even try to replicate them, and prefer to talk about fakes,  etz...
  I will continue on, "blindly" as mentioned by some guys. With no income to draw from. Working with recycled materials when possible. One step at a time. That is all I can do for now. And if I have some success, I promise to show it, and explain what I've done,  as I always have.
  I enjoy the process, and working with my hands on an interesting electronics projects, as much as seeing positive results, therefrom.
But, Free Time,  is the only thing that I have, at this moment. Not Free Energy.
   As you may all know this is dangerous waters we are threading. Both for the ones with self runners, as well as for inexperienced builders, like my self.
That is why I prefer to stay with safe non-shocking magnetic energy generators, if possible, even if it means connecting them to solar systems, instead.
As High Voltage heterodyning changes the parameters, which I'm only now beginning to understand.
NickZ
  Grum:
   I did see your PM. Thanks again for the offer.
   We need to know if the scope is able to measure the frequency spectrum, correctly. Or at least what it can read, and if it will serve our purpose.
  I know nothing about scopes.
   Also, about the shipping costs from UK to CR. as well. May not be worth the costs involved. As shipping on heavier objects is not cheap, at all. Nor are the import custom duty fees, here.
                           NickZ
