0 Members and 434 Guests are viewing this topic.
T-1000
Quote from: stupify12 on October 20, 2014, 12:50:42 PM
The Bifilar Grenade Coil is the Insulated shiny metal conductor= Elevated Capacity.
The Kacher Circuit is the Resonant Tesla Coil that work as Transmitter here of Rays/Radiation.
That is correct understanding  8) Also N. Tesla ment in his patents exactly that.
Also the http://en.wikipedia.org/wiki/Regenerative_circuit method can be used to amplify received power in grenade coil just in this case it adds amps to the voltage gain and there you have summary output power...
Cheers!
stupify12
Calculating the length of the Grenade Coil.   Let's say we like to stay put in frequency of 3Mhz.
Here is the formula used by the calculator of the wavelength (lambda)
depending on "v" (velocity of the wave) and "f" (frequency).
wavelength frequency formula
Lambda=Velocity / Frequency.
V=Velocity of Propagation of Electrical Disturbance
F=Frequency
Lambda= Wavelength
Tesla Constant Velocity of Propagation=185000(One Hundred and eighty-five Thousand Mile per second)
Let's convert Miles into Meters:   185000 Miles =  297728640 Meters
All the guys here like to used the 3Mhz Frequency so let's use this.
http://www.wavelengthcalculator.com/ Using this online calculator.
Velocity :297728640 m/s
Frequency: 3Mhz
Wavelength= The answer is 99.24288 m
1/4 of the Wavelength: 99.24288/4 =24.81072 meter wire to wound.
Just speculation.
MEOW ;D ;D
d3x0r
http://www.nteinc.com/specs/2300to2399/pdf/nte2328.pdf  (2sc- thing.. 25Mhz)
the NTE327 on package says 40Mhz
Still can't get kacher over 500 some Khz...
put two variable resistors to power and ground to the base; I can tune to get more output with a low resistance to power... resistance to ground being lower than a lot is bad...
the wire is 48-49 meters... which is 6.1Mhz
putting a bar of ferrite in it increases output and decreases amp draw...
Inductance of 3.75" diameter 3.75" length, 150 winds (each turn 0.31m) maybe it's a little shorter than 48 meters...
1.455mH; resonant capacitance of 536Khz 1.4mH is 60pF....
I'm not seeing how to attain the proper goal :/
T-1000
Quote from: d3x0r on October 20, 2014, 03:09:30 PM
You need to lower interwinding capacitance so the Tesla secondary coil winding spacing should be at least on every second turn. Ruslan used 0.8mm diameter wire(oxygen free) as he told in latest video https://www.youtube.com/watch?v=hpYj4YT_DIs
Jeg
Quote from: itsu on October 20, 2014, 10:23:13 AM
Sounds great Jeg, good progres.
Concerning my Kacher, its even more simple, just the 2SC5200 transistor and a 2.2KOhm resistor, see diagram.
Mind you, there it shows a PNP transistor, my 2sc5200 is a NPN, so change the plus/minus.
In front of the 1:1 transformer i have a variac connected to mains so i can vary the DC from 0 to max. 400V DC
Regards Itsu
Tnks Itsu.
After some consideration, the only logical explanation is that my 2n3055 transistor is not so quick as yours, and small voltage changes affect the output frequency. I can't see any other reason for this discrepancy.
