0 Members and 76 Guests are viewing this topic.
d3x0r
Quote from: MACEDONIA  CD on November 23, 2014, 06:45:36 PM
Hi
Hello; please resize images to 1024 width... it breaks formatting for the entire page if you post a huge picture.
if you really want ot share the high res use a link to another size plz... or zip or rar it...
Cap-Z-ro
Is there not a way for Stefan to set a limit to the size pics the site will allow ?
Jeg
Quote from: Hoppy on November 24, 2014, 10:13:39 AM
Yes.
Then if you like you can try this to see if you have any different results.
In Ruslan's circuit add a second diode between grenade and ground, cathode at ground.
The 10uF cap straight to the ground.
Katcher's and mosfets negative straight also to ground.
Magnetic poles of both inductor and grenade to be on the same side during each pulse (important).
Inductor circuit without ground cause it is already polarized from yoke.
Happy experimenting :)
magpwr
Quote from: itsu on November 24, 2014, 10:01:03 AM
Hi Magpwr,
i don't know why you keep refering to the below screenshot when talking about 60th sub-harmonic.
Surely you can see that with 1 period of the big sine wave we have 3 periods of the smaller tesla (Kacher), meaning
there is a 1 to 3 frequency relationship, not 60
Or do i see/understand that wrong?
Regards Itsu
hi itsu,
You are 100% right.  :o The old video was using 3rd sub-harmonics for the old device.
The older video is using 3rd sub-harmonics  of bifilar coil 165khz which is 55khz.
This also produce "nice alignment" as shown in my last attachment.But i do not want to confuse other by bringing up the harmonics used for the old device.
If you dig into my older posting <2months back i have mentioned 120th 60th 30th 15th sub-harmonics which can produce nice alignment.
But i did not mention 3rd sub-subharmonics as this was related to the older simple version of Akula device.
I do not want to confuse others by using the old device harmonics since it's a big drop from 60th sub-harmonics to 3.
But the circuit i am designing already caters for div by 3(using 1x74HC4017 via jumper setting) just in case as last resort if i need to work on old device diagram of Akula. :)
Hoppy
Quote from: Jeg on November 24, 2014, 10:59:36 AM
When you fire it normally you will see a difference at your output bulbs. The higher the Katcher's voltage the higher the effect. While firing Katcher you will see a decreasing of your mosfets consumption in parallel with more brighter bulbs. No capacitive effect of your hands except if you almost touch your inductor.
Jeg,
There is a power balance going on between the Kacher consumption and the grenade, so any change to one will affect the other. Its the total current consumption that needs to be monitored closely. I can see brighter bulbs with less mosfet consumption depending on how the device is tuned. The bottom line is that the device is electrically running at around 55% efficient.
