0 Members and 411 Guests are viewing this topic.
starcruiser
@Bat1,
The Box shown is supposed to be an Inverter, this is similar to the PSU used in the Akula design, albeit reversed (12/24/48v to 120/220vac), I am sure this is a sinusoid unit and not a squarewave output type. This is supposedly running the transformer box that Tariel is holding in his hands. Thus the comment of a similar operating principle/design.
We are still looking at the same type of generator (electrostatic?) that charges the capacitors after going thru a rectifier (should be a high speed unit due to the operating frequency).
Regards,
Carl
Enjoykin
Hello builders
Doesn't look to dense - maybe we need some more British fog here ??  ;D   ;D
Hello starcruiser,
You have right - it is factory made powerful sinus inverter. I have schematic somewhere in my archives.
But maybe shown inverter was modified !! Who knows.
NickZ - thanks for picture. I have no idea about weight. Any conjectures have no sense for me.
New replicator in Roman club  !!  :D
Zeidy Jimenez 300 Watts output from his BTG
http://www.youtube.com/watch?v=_QGVrPSzjZI
His mail : With further improvements and testing, using a12v battery, the bulbs are 110v, 100w. (300 watt load, but not lighting fully bright using 12v input source.
NickZ
  Not a new member, that is my video, it got posted under my wife's name a while back.
Hoppy
Quote from: Enjoykin on April 28, 2015, 06:41:59 PM
Hello builders
Still not dense enough. You need to master Windows Paint!  ;D
NickZ
   I've been trying to duplicate the effect that was shown by Ruslan, when he connected just a single low wattage bulb (25 watt bulb, or so), to the output of the grenade, to get the bulb to light using only the Kacher and the 3 turns yoke coil circuits. Which is also connected through the series tuning cap(s) to the grenade 12, 12, turns induction coil, or resonator, as some guys call it.
Well, my results are that I can barely light the small 25w bulb (it does glow), but not really due to the help of the Kacher's HV output in sync with the resonator coil.  When I disconnect the Kacher circuit, very little difference happens to the small bulb.
So, that small bulb is lighting mainly from the output coming from the yoke/resonator circuit, by induction to the grenade's output coil (168 turns coil). But,  not from the Kacher/resonator sync up.
If I connect a single 50 watt bulb to the yoke at the 28 turns secondary coil, the 25watt test bulb lights a bit brighter, but still pretty dim, but not as dim as without the 50 watt bulb connected to the yoke's 28 turns secondary coil. If I place a 100w bulb, instead of the 50w, the small bulb does not light, at all, only heat is felt coming from it.
  Anyway, that's as far as I've gotten with those tests. Which proves to me that there is very little interaction between the Kacher, and the grenade, if using only 12v input. if a higher input voltage is used, like 24v, of course the small test bulb will light up much better.
  So, although the small 25w test bulb does light,  it shows me that I still have to improve on both the Kacher's output level, as well as obtaining the right frequencies for the proper heterodyning to take place. Ground lines also only add a slight higher output, when connected up to the device.
  As always, any ideas are welcome. As I really can't understand what Ruslan is saying in his videos.
