0 Members and 446 Guests are viewing this topic.
MenofFather
Quote from: NickZ on June 16, 2015, 11:06:35 AM
  Notice how he does NOT leave the second bank of light bulbs on for very long, before disconnecting them, and leaving only the first bank of bulbs on. What does that mean?
  Anyways,  just some thoughts...
He explain in video, that diodes is hot and he not want burn diodes. Because on output is DC.
NickZ
     MenofFather:
     Good to hear from you again.
     Thanks for the info on the reason why Ruslan turns off the second bank of bulbs.
      I had thought as much, either the fets or the diodes getting too hot, or both.
      T-1000:  Ok, so if the fets are NOT producing the high output (4KW, or so).  And aren't getting too  hot, either... What is the part of the device that does do this?
      As this is an important point, and I did not really understand your last explanation, fully,  can you further explain what you know about that, please.
      I have heard about the Kacher HV at the antenna creating a Capacitor/Coil combination with the grenade. But, I've not seen those results, as yet.
      Once I have my scope, I'll be able zero in on the running frequencies, and further tune the circuits to a better resonant peaks, etz...  Till then,  I'll do what I can.
Tomtech29
T-1000:
or you received a message?
Thanks.
magpwr
Quote from: Tomtech29 on June 16, 2015, 12:06:33 PM
magpwr:
The one on the left is the TL494 with the mosfet driver and 8pin MC34063 you know these circuits and you have to have a full scheme?
where can I download them?
This right also does not look like this: (Akula) show 'me please?
It is interesting that this is no longer a need (Pll) push pull 15Khz. no synchronization (winding core now has 4 turnovers ) Nickż  and I think that it is not not based on the output power from the element
greater attention is focused on ,providing a signal by tesla coil ! -and he says that it 1.5MHz frequency selected rips him.
But that is how the oscilloscope screen to shoot vice versa pulsation I have not seen such a signal?
already appeared modifications and no one has ever repeated the old model!
and so much what to say that will show you how to make (as you think)?
lack specifics.
Here is something you created:
hi Tomtech29,
It is pointless to replicate something if we don't know if it's fake or for real beside that you will still need to know how this low and high frequencies interact with one another.
At this point on i will not talk about Ruslan unless he got something credible to show.
At this point base on the result of my spectrum analyzer i already know the interaction between the low frequency and high frequency on my assembled kapanadze coil.
This is for my eyes only since the rest of you may not even got a scope or spectrum analyzer.
I don't know if any of you noticed by now(base on my recent posting with attachment) for my tesla transponder 2.0 with interrupter .
I was using low frequency pulsing at primary to achieve higher frequency 4x or more at the secondary to the Antenna.
Similar concept to Don Smith device i say.Like a fool i am showing you my prototype model which was done long time ago with short circuit test-
http://www.youtube.com/watch?v=z-MZSavyM8U
At 4x or more than the input frequency it's no longer about resonance it's about harmonics.This is where the magic happens especially if short circuit test don't effect the battery current draw at all. 8)
Hoppy
Quote from: magpwr on June 17, 2015, 12:39:03 AM
Hi Magpwr,
Consideration needs to be given to the response time of your meter display and other factors. When doing supply current measurements, ditch your meter and monitor the current by scope with a suitable value non-inductive shunt resistor and low pass filter network.
