0 Members and 446 Guests are viewing this topic.
Hoppy
Quote from: T-1000 on June 25, 2015, 04:40:42 AM
For people who did not solder circuits not winded coils and just keep whining about fakeries - this thread is not for you... You expressed your opinions and we do not need to see them repeated thousands times. We also know you never go outside of  the conventional science box.
Instead of whining about fakery you better find a use of Tesla Impulse Technology and use of very efficient circuits instead. This will be far more constructive than just forum flooding with negative posts...
I solder circuits and wind coils and this thread is for me. There should be no discrimination on content, whether I talk about fakeries or get into build discussions as I have in the past.
T-1000
Quote from: Hoppy on June 25, 2015, 05:07:43 AM
Well, the reason why this thread was separated from main Kapanadze thread - the stuff is actually is being built and discussed here. The discussions on the fakeries should be continued on http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/
Also this is getting hard to find stuff when thread go over 500 pages with not useful posts which are starting to take most of space on thread...
T-1000
Also there was teamspeak recording of Ruslan where he explained way of winding coils and critical moments - https://www.youtube.com/watch?v=4DyLoXd4Ivk
Obviously it is in Russian and someone will have hard time to translate 1 hour length conference..
NickZ
  Hoppy and All:
  Every time I hear another false cry "fake". from the naysayers on this thread, it takes some motivation away to continue on with you guys.
  Fake fake fake fake fake...
   Are you happy now, you got everybody thinking that you're right.  When you're dead wrong...  Do you get paid for this, or are you doing it for fun.
   You will always find something to complain about. But, it doesn't look like Ruslan, nor Akula care about your whims.
   Yes, Hoppy you have the right, so does TinselKoala, Void, Magpwr, Bat1, AlienGrey, and any other person that thinks that what they are seeing is faked. You have the right to destroy the hopes and ambition of the rest of us, that are actually working and doing something on this thread, with negative thinking about things that you really have NO idea about.
   What is your intention? While you ruin the project for anyone that is really interested in finding the truth of how these devices works.
   Several people have left this thread already due to the constant attack on this theme.  Just to find you along with Tinsel, doing the same in the other forums.  What a waste of talent.
  MileHigh is another example of a wasted mind.  Just who do you guys think that you're protecting from what you think is a fake.  NOT ME!
  Anyways, I hope that you're having fun at it. At least...
  Continue on wasting more time posting sh!t for facts. What a bore...
starcruiser
To all,
I will be showing circuit boards, no boxes. I am looking to understand the operation thus the incremental steps and testing.
The next step in my testing is to secure the HF diodes, the ferrite rod and breadboard the logic circuit to adjust the Tesla trigger and see how this works out. I will then see if I can produce enough DC voltage / current to run a small 400W inverter by rectifying the output and using a large storage cap to buffer the output. I will be using a SSTC driver initially to drive the Tesla side with a input that allows external modulation, this is where I will feed the synchronizing signal. After this is done I will start to use the frequency mixing and want to see if the design will support 60Hz as a LF source instead of the 27Khz, so I will be showing this stage of testing prior to the yoke design as well.
I will eventually attempt to loop this but need to check each section and see how it reacts and what results I get. No cutting corners here. I am thinking I might need to run at the higher frequency to get results (read current) but we shall see.
Ideally I want to see if a solution could be derived from components and circuits that are readily available without having to design and assemble custom circuits and drivers, this would allow others to build the same without having to worry about special circuits or tuning procedures (if possible).
I do have a yoke on hand and will build this driver circuit if and when necessary, I am not in a rush as this is a hobby for me and family and work life has to come first so this project might not progress as fast as some would like so all I say is to have patience. I will continue to share as I move along.
Regards,
Carl
