0 Members and 418 Guests are viewing this topic.
Tomtech29
does anyone have any idea?
yet on this Tesla coil system something similar to what I presented.
Dog-One
Quote from: Tomtech29 on July 10, 2015, 10:20:02 AM
Dog-One
I'll stick this in your instructions guys it is a good idea.
Thanks. :)
You are welcome.
Here is the specification/supplier for the toroid transformer:
http://www.cwsbytemark.com/images/CN80-50-20Gfi.pdf
Running frequency with this setup appears to be right around 18.7 kHz using Kemet high power pulse capacitors, a 60 watt light bulb and 24 volt power supply for a load.  Use the current sense to find the peak amplitude--this is where you set the running frequency and the value of the capacitor that is in series with the induction heater coil.  Once you have the frequency locked, keep it locked and adjust the other two capacitors to achieve the highest voltage amplitude in the grenade coil.  Sorry, but that is about as simple as I can make it.
Tomtech29
He was referring to coil L1 = 18.7 meters and 37.5 meters L2
from what shows they are not so wound as he claims
T-1000
As a side note, Ruslan is going nuts with his explanations hitting ignorance of people and even he have hard time to explain how this generator works because people still not get it. I comfort him for so many sleepless nights and long videos as it is very similar situation I was in on 2010...
In the latest video he tried to explain from conventional radio electronics standpoint but even that is not helping for people understanding with what exactly is required to make things work.
For a ratios and wire lengths I already translated in previous posts - the wavelength = wire length and all calculations on frequencies and harmonics are based on that. And it is the same method of calculation like N. Tesla did more than hundred years ago.
Void
Quote from: Tomtech29 on July 10, 2015, 10:36:47 AM
Thanks TomTech29. I see. Yes, it does appear that some things Ruslan says appears to
contain contradictions, but I don't speak Russian so these apparent contradictions could be
due to misunderstandings for all I know. :)
All the best...
