0 Members and 446 Guests are viewing this topic.
NickZ
    Tomtech:
   Are you using the 0.47uf 2000v caps, or not?
   Notice that he further adjust the frequency at times in the previous video, by adding another smaller 0.22uf cap in parallel to the two 0.47uf caps, for three tuning caps in all, at about 1.2uf total.  Of course your set up may work differently.
  Maybe you can post another picture, I don't remember what your device looks like.
  Magpwr:  The inside "choke" is not a Tesla coil. It is a based on the Hendershot coil system, and it had 50 turns of insulated wire connected only to the small tuning cap.
You are looking at a coil used in the testing of the previous non-self running device.
Tomtech29
on a given film, we see a closed circuit parallel LC"
with a thin wire so as to have a magnetic field energies supplies with 28 windings do not know what's going on with 3 or winding connected?
Tomtech29
Nick is so when I have connected only one 0,47uF this frequency is 21kHz when I add another we have about 1uF is the frequency at 15kHz maximum peak have most probably next only reduces the frequency of the check that my coil inductor are only two jars of 24 + 24.
adding another jar on the inductor will result in a higher operating frequency of 27Khz if I'm right? :-\
Tomtech29
magpwr
so when you watch you will see that the generator is set to about 75% shorter cycle course this time uses less energy by heating of the transistor and the loss.
- of 2 amps and resonance is achieved at the expense of 12 amps so because of a good core and a thick cable on it 6mm2.
However, in the next film where an incandescent lamp 300W. with high power and power from the power supply almost very low energy consumption!
what is cool?
NickZ
  What's going on is that that coil is not the one that Akula later used on the first self runner.
  That was his previous try at obtaining HV. But, later he used the isolated Hendershot style 50 turns coil/capacitor and an aluminum sheet coiled up inside the pvc pipe, without any magnet wire below it. This was what MenofFather mentioned that Akula had said,  that this "choke" could also be made using even more turns, like 300, or so.
  That older TL494 circuit board is what I believe that GeoFusion had replicated, and he may have the schematic for it, as well.  Looks simple enough, if it works, that is.
