Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1021 Guests are viewing this topic.
GeoFusion
Meno
thank you for the help on schema's. :)
guesing we'll reach somewhere now. and have to do minor adjustments on the Mosfet Circuitry.
:D  experimenting time again!
guyz will give updates aight, srry was busy these days. Work is killing my hours to be on the bench.
Btw, last week I managed to build a Flash back arrestor Home made out of Aquarium Airstones, for the torch, and works flawlessly.
CHeerz :).
NickZ
   MenofFather:
   Have you connected your set up like the diagram? With the 168 turn output coil separate from the 25 induction coil?
   What about using the power from the voltage coming out of the grenade's output coil to directly pulse the Kacher secondary coil? Or, the Kacher's 6 turns primary coil,  without needing a separate Kacher driver circuit?
MenofFather
QuoteMenofFather:
Yes.
QuoteWhat about using the power from the voltage coming out of the grenade's output coil to directly pulse the Kacher secondary coil? Or, the Kacher's 6 turns primary coil,  without needing a separate Kacher driver circuit?
Acording last Ruslan explanations here now no kacher. Now is controled Tesla coil, how he call. How you see emalated coil one end go directly to ground. In kacher it go to transitor base.
On out 28 turns windings, I think, can be too hight voltage (so in my last schematic I add choke to lower voltage (choosing proper choke and capasitors for needed voltage)). If you conect controled Tesla coil from granade output, then be more higher voltage than from 28 turns windings on yoke.
Ed morbus
Watch
Ruslan Kulabuhov energy device open internals 2 of
