Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 274 Guests are viewing this topic.
NickZ
   As Geo's device is running in the audible sound frequencies, I made some tests using a couple of different audio spectrum analyzers. Both analyzers are showing the same main running frequencies, at just under 7kHz. This is up from his previous normal yoke core device tests which were running at just under 5kHz for his main peak, with two other higher frequency peaks also, but, both other peaks showing lower outputs.
   Geo has one main running frequency on his last video, which is at 6.98kHz, but when he places his hand near the device, not only does the frequency change, to lower frequencies, but also several more new peaks come into view, as the hand movements creates more static like noise or interference. All the several new peaks are of lower frequency than his main one, which is at 6.98kHz, or thereabouts.
  Moving his hand around the device, does not produce any higher outputs, just a dimming, de-tuning and interference effects, at least that is what I can see on the spectrum analyzer.
   I don't think that it's a good idea to remove the ground while the Kacher is running. As that can kill some of the delicate components due to the HV running all over the device.
   I also think that the mediator coil can be allowing for over-currents throughout his device, which may cause overheating problems on the yoke and grenade coils, after some prolonged running times, besides being unstable, and hard to control.
   Any ways, he asked what we think about it,  and that was my reply.
Zeitmaschine
Quote from: stivep on October 30, 2016, 05:52:53 PM
For interested industries the goal is:
1. to use this videos  as  statistical tool to count  that specific targeted public response.
2. to make next step based on previous experience.
Does »this videos« include Accula and Ruslan (etc.) videos also?
The good sign is:
We see FEAR of  specifically involved industries
That FEAR is so eminent in its form , so drastically exposed, by now that it becomes visible.
and that is  a very good sign.
Is that fear eminent because some people in the forums are close to a working device but without knowing it? Then this would require that someone of the »interested industries« exactly knows how such a device works (and that it is possible at all), so they know when someone comes (too) close to the principle.
Then we also have a statistical tool to count: The more strange Kapanadze replication videos emerge, then apparently the closer we are to the solution how the Kapanadze device works.
Hoppy
Quote from: verpies on October 30, 2016, 08:32:38 PM
@Hoppy
Do you think the position of his hand affects the IO currents of this device by altering gate signals driving its push-pull circuit ...or in some other manner?
Yes, almost certainly but I would like to see Geo repeat the demo using a battery supply and also to disconnect the push-pull supply during the demo, whilst the Kacher is still running. The system is consuming around 120W according to the average current reading on the ammeter, which is probably about right given the fairly low illumination level of the bulb, which appears brighter on video than it really is.
There may well be other contributing effects, as it appears that the HV from the Kacher is charging the grenade circuits capacitance by using the earth wire as a return back to the PSU. As has been repeatedly said before, these experiments and demos should not be conducted using mains PSU's.
dewetw
Hoppy I agree: don't leave room for unnecessary doubt.
By following a methodical process whereby most thinkable assumption are eliminated early on a more concrete certainty can be established sooner rather than later. That is why I sat down and built myself a battery powered bench top power supply for experimenting with right off the bat...
justawatt
