Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 2449 Guests are viewing this topic.
AlienGrey
Try this type of circuit values depend on frequency it all needs to be fast keep wire ends short. try a fast HEF4093 set it up on a bread board you need a scope.
Note reversing R and C placing has the inverse effect on the the next stage if used thus moving it up and down.
Hoppy
Quote from: NickZ on October 27, 2017, 04:39:45 PM
   Void:
   I have an imbalance also. So...  Does not seam to matter too much. And I still can get the RM signal,.also, even when using just the 18v laptop adapter.
Replaced the bad resistors, but it did not help bring my PS back to life. Bummer!
Nick,
Get a couple of old car batteries with some auto lamps for current limiting. If you continue using your 18V laptop adaptor you'll run the risk of smoking that too unless you add a blocking diode. Also, if possible add a PI filter as suggested by Void.
itsu
Quote from: soliman on October 19, 2017, 06:48:31 PM
the photo above is correct. and refers to the stalker circuit.
I want to show you this other photo.
as you can see the photo above represents the gates mosfet
the one below represents pins 9 and 10 of the TL494
this means that the delay system has control over the mosfet to work at the right point.
Soliman,
i added also a TC4093BP behind the TL494, like can be seen in the red circle below.
But allthough i indeed can delay the TL494 signals quite a bit, i cannot make them to be wider, like more then the 44% duty cycle coming from the TL494.
So how did you manage to increase the TL494 duty cycle from its max. 44% to your 49.8% seen in your above post?
http://overunity.com/12736/kapanadze-cousin-dally-free-energy/msg511952/#msg511952
Video here:   https://www.youtube.com/watch?v=Aof4J0cHs2g
Itsu
AlienGrey
Quote from: itsu on October 28, 2017, 06:22:46 AM
Soliman,
Itsu
Itsu, it's just not that alone, it's other bad habits that are hard to drop and your talking about ferro resonance and some you think are tried and tested, masters publish circuits that are fake and don't work and misleading information.............it's all here in this data base. Look up frro resonance on the INTERNET and different types of ferrox material.
itsu
AG, I fail to see the logic in your response to my post, i guess it was just a general post you wanted to throw out.
Anyway, i have added a little video to my above post to show the delay effect i have with this added TC4093 chip.
Guess i need to delay the trailing edge of the TL494 pulse, not the leading edge as it is doing now.
Any suggestion on how to do that (if even possible) are appreciated.
Thanks,   itsu
