Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 474 Guests are viewing this topic.
NickZ
   Guys, I do connect the aluminum ground lines  to a iron tube that actually goes into the water of my well.
   I don't use the well now, as I'm connected to municipal water system. My ground system is similar to how Akula has it in his backyard. In a wet spot, where dripping water can be heard right next to his ground connection.
Maybe, Not so in Germany, where he could not get it to work. Perhaps the reason,
Void
Hi Nick. What I meant was you need to connect to a pipe that goes down deep in contact with
the actual dirt. If the pipe is just inside the water well but not in contact with the dirt
for most or all of its length then that would probably not work as well for an earth ground. If you mean the
metal pipe is in direct contact with the dirt all the way down deep, then that should be a lot better
earth ground to connect to.
All the best...
Hoppy
Quote from: NickZ on November 25, 2017, 09:24:32 PM
I remember that classic video where the earth wire appears to disappear into the iron pipe and not connected to the earthing bolt.  ???
AlienGrey
Quote from: Hoppy on November 26, 2017, 04:30:00 AM
Hoppy it's not a good photo and you can look at it 2 ways/
But more to the point what happened to your encounter in the thread when you asked Mr King to up date you
regarding his theory regarding changing the drive oscillator for a Radiant oscillator did he send you an up date as requested ?
As he disappeared to about then, so what happened ?
Allen
Hoppy
Quote from: AlienGrey on November 26, 2017, 05:04:34 AM
Allen
Agreed but not bad from crappy video quality.  :) Which other way do you see it?
Please direct me to the relevant posts with MR King, as I don't recall that particular exchange with him.
