CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
a-XXX XXX XIV. trying my hands on wm2d, the weighs configuration on the see-saw.... it's still balanced
helloha
Analysing of Bessler's Clues 45.
< Candidate for the Double-ended Club >
"each child can swing (or you might call it "step" as it uses a club as a "leg") from the top of one broken column to the top of the next broken column by positioning his heavy club on the ground between the two close columns and holding on to the handle end to swing over to the top of the next column. Then he rotates the handle end of his club to maneuver it between his current column and his next intended column so that he can again "step" or swing a small angle over to the top of the next intended broken column."
"If the clubs are even heavier by being double-ended, then instead of rolling them to the next position, they may be alternatively transported between the columns by switching ends. A double club may be moved in seesaw fashion by leaning it against the current broken column that the child is on and rolling it over the top of the column (assuming that there is enough room for the child to stay on top of the column). The double club is pivoted with a circular motion with one end going up while the other end goes down."
- refer to the image and video for speculation of the basic concept structure of the double-ended club
- 'rolling it over the top of the column', does the 'it' refer to the club or child ?
1. if child, then this clue can link up with the child using the club as its 'leg' description (basically mean the club will roll the child to the next top column)
2. if club, no idea, how to get the club to roll over to the top of column ?
- 'enough room for child to stay on top' what does it mean, and how ?
- does this double-ended club have any connection, or involvement, to the mechanism of bi-directional wheel ?
helloha
a.1 Candidate for the Double-ended Club
- just a slight modification
helloha
a.2 Candidate for the Double-ended Club
- refer to image and video to spot the modification
helloha
a-XXX XXX XV. trying my hands on wm2d,  utilizing the human and gravity v4, adding a wind turbine
previous version here
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg408041/#msg408041
