CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
worker
Hi, forum, any comment on the below design?
Diagram illustrates equilibrium forces to give vertical movement with minimum effort needed to tilt the platforms.
Platform cylinders have equal displacements; hoses connected to give equal force on each side, no matter where weights are positioned. Adding an amount of lube to one side of the cylinder circuit, tilts the platforms, weights move accordingly. Weights roll from left to right as required to gain vertical movement.
Control system could be a control valve positioned at upper/lower limit of the parallel frame travel limits
Lower cylinder (acting as a pump) is to extract over balance forces, certain amount is used to tilt weight platforms.
Q. feasible OU device?
helloha
Quote from: worker on August 11, 2014, 03:02:03 AM
no idea about the platform cylinder, platform tilt etc... , so replaced those with just springs to, at least, see how the basic result will behave
helloha
a.8 Candidate for the Double-ended Club
- continuum from a.7 Candidate for the Double-ended Club
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg413255/#msg413255
- link to misc short video simulation (although sim is poorly done, unstable with lots of bouncing movement.... >o<)
http://www.mediafire.com/download/vn8wr3i5h159fq4/double-ended-club-direction.zip
helloha
a-XXX XXX XXIV. trying my hands on wm2d, Roberval Balance vs See-Saw Balance v8
helloha
a-XXX XXX XXV. trying my hands on wm2d, Roberval Balance vs See-Saw Balance v9
