CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
helloha
found my old wheel modeling (think it's last year when i model this wheel, with failed simulation, obviously) when sorting through my file directory. Showcase this wheel now before it went dormant again.
norman6538
That wheel is clearly bottom heavy. Look at where the CG is and where the most balls are.
A self rotating wheel will need to be top heavy or side heavy.
It has a great look and great mechanics but.......
Norman
lightend
Can some one explain CG to me a bit, for example,
I have a 1 meter stick, at each end is a 50cm wheel with a 1kg weight inside (alternator attached to the inner of the wheel so when the wheel spins the alternator turns).
as the weight will always be at the bottom of the wheel, that would throw the CG down the 1m stick by 25cm.
would that 25cm of off CG be enough to loose any potential power gains?
Second question, regarding the picture below (roughly drawn on paint (im not pc world guy)),
with the electro magnets only kicking in when they are needed, would that cause ou or not?
im sure both these have been tried and tested before, they are just something that have been in my mind for a while.
sorry for not finding the correct places, I just wanted an active forum with allot of expertise looking at it daily.
helloha
Quote from: norman6538 on April 20, 2013, 07:43:07 AM
Norman
Nice description...
and it does look good  ;D
